Found this and it deserves a bump for others to see.
Bump for a nice refresher on stub axles
Hi,
Thanks guys, your help and knowledge are so appreciated! I've been looking for infos on what complete axle shaft assembly I could use on my 1981 SC roller with a 915/73 trans (108mm flanges+6x10mm bolts) and I just found the info on this thread => late style axle shaft assembly will fit in my 81 SC wheel hub, like this one : https://www.pelicanparts.com/catalog/SuperCat/0807/POR_0807_SUSAXL_pg1.htm#item1 Thanks again! |
| All times are GMT -8. The time now is 08:46 AM. |
