confused on vacuum hose routing
Need help on figuring out vacuum hose routing I have a 1983 911sc ,with a vacuum controlled warm up regulator.::
http://forums.pelicanparts.com/uploa...1276797211.jpg
http://forums.pelicanparts.com/uploa...1276797267.jpg http://forums.pelicanparts.com/uploa...1276797297.jpg Some pics when I was installing the MSD box. I have plenty more if you specify the location. |
Do a search. Within a few threads you'll find links to diagrams which should help you out. By the way, the hose coming from the pop of the WUR is just a vent, not a vac line.
| All times are GMT -8. The time now is 01:15 AM. |
