scca_ita's Avatar
WHere to get Oil lines for Oil Cooler
Hi
Any recommendations on where to get Oil lines made for a front oil cooler in an RSR style bumper? I need AN16 to the standard hard lines in the fender.
Old 12-21-2001, 10:32 AM
Hilbilly Deluxe
emcon5's Avatar
http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=54833
82 911SC Coupe
GTI Cup #43
Old 12-21-2001, 11:46 AM
Pegasus Racing, AJUSA, Mocal and others sell the 30mm-to-12/16AN adapters you'll need to attach to the factory hard lines.
Summit Racing usually has the best prices on AN fittings and braided hose. Check the above link for more options.
As Aeroquip, Goodridge and Earls AN fittings can be reused, they are also more costly than one-time, crimp-on hose ends. One cost-effective strategy is to have one hose end (straight, 45º or 90º) installed by an industrial hydraulic hose shop, take the unfinished hose assy. to your car to determine exact length, then have the shop crimp/install the other end to that length. Make sure the fittings they use don't restrict fluid flow. Some brands have a larger fluid orifice for less restriction. Throughly clean the inside before installing.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 12-21-2001, 12:33 PM
