-   -   Weird Alternator Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/548739-weird-alternator-problem.html)
ausgezeichnet 06-18-2010 03:46 PM
Hey Guys
I went to replace my fan belt and when I removed the outer pulley half I noticed this groove that had been worn in to the square mounting on the alternator shaft. Can this be filled in with some type of epoxy or liquid metal or do you think I need to replace my alternator?
Mike
http://forums.pelicanparts.com/uploa...1276900853.jpg
rick-l 06-18-2010 04:20 PM
That's part of the fan.
HawgRyder 06-18-2010 06:00 PM
I have the same problem with mine and ended up installing 2 pins in the holes of the fan that stick out and grip the pulley.
It may not be concours....but it works, and the pulley does move in relation to the fan.
Bob
john walker's workshop 06-18-2010 06:38 PM
i've carefully welded them up and reshaped with a file and disc grinder. gotta take it off first. the outer pulley half was loose and will need to be replaced of course.
rick-l 06-18-2010 08:12 PM
Is that steel?
ausgezeichnet 06-19-2010 01:43 PM
Thanks for the feed back. Does any one know what type of metal the fan blade is made of?
grizzfan 06-19-2010 04:59 PM
I believe yours is made from an alumninum-magnesium alloy.
Tom
rick-l 06-19-2010 06:34 PM
even the hub?
304065 06-19-2010 06:39 PM
The hub is steel.
dtxscott 06-20-2010 07:01 PM
Curious.... What causes this groove to appear?
James Brown 06-20-2010 09:08 PM
from NOT putting the pully on correctly, the washers cut into the fan shaft and wear over time.
RoninLB 06-20-2010 09:44 PM
Originally Posted by ausgezeichnet (Post 5411896)
Hey Guys
is it also worn on the opposite side of the fan hub?
also i think the fan hub is softer than the steel pully half?
and it should take a temporary fix with a 2 part epoxy
ausgezeichnet 06-21-2010 05:59 PM
Mine is only worn as seen in the picture. It not worn all the way around. Mine was assembled like in the picture below only I had three washers on the outside and none on the inside. I know there should be a total of 6 but some post state it's not an issue to have less. Other than this how else can you install the pulley incorrectly?
http://forums.pelicanparts.com/uploa...1277168186.jpg
AlfonsoR 07-15-2010 07:43 PM
Aus,
It's been some time since you posted this, but....
I am currently experiencing the same thing. I believe the cause is not the washers, but the pulley rocking back and forth. So in other words, it has enough wiggle room (maybe the shims do wear a little over time) to move, so that means it is not being captured completely by the nut.
So some things that could cause it:
1. worn shims - get new ones
2. using wrong number of shims - there should be 6
3. incorrectly installed cup washer - I am trying to verify this, but like in your diagram, it looks like the flat part of the cup washer should be pointing out. On my car it was installed flat facing the alternator.
4. incorrect aligmment of belt pulleys - make sure the fan housing is installed correctly. There is a dowel pin on the engine case that pokes out and is supposed to slip into a notch on the fan housing.
5. not related to what caused your problem but an issue that has come up a few times on the forums are complaints of the Porsche (goodyear) belt being too tight. I had an "opportunity" to order both and try both on installation and noticed a big difference. The conti is much easier to install. I took measurements and found the ID of the Conti to be 706 mm and the goodyear to be 693 mm. I also had a Dayco belt and it measured 709 mm.
Good luck.
ausgezeichnet 07-19-2010 02:05 PM
AlfonsoR,
Great suggestions. Thanks!
Mike
ausgezeichnet 08-09-2010 04:28 PM
Can anyone confirm which way the cup washer should be facing as your are standing at the back of the car looking at the alternator ?
http://forums.pelicanparts.com/uploa...1281396161.jpg
http://forums.pelicanparts.com/uploa...1281396196.jpg
Thanks.
Mike
James Brown 08-09-2010 04:44 PM
It should go in like picture #2
Wil Ferch 08-09-2010 04:44 PM
First of all ...some very bad info floating around in here.....you ALWAYS fit 6 washers....those you do not use between the pulley halves go under the mounting nut over the outside pulley half. NOT doing this allows the removable pulley half NOT to get real tightly attached to the fan half of the pulley, and will cause exactly the wobble-wear you describe around the rounded-end rectangular male piece. I challenge also the statement that some say you don't have to use all 6 shims. If you do a search you will find most credible people ( like the shop manual, or Bentley manual) will say to use all 6.
ausgezeichnet 08-09-2010 06:57 PM
Thanks James. That's what I thought but none of the diagrams are very clear. Also, since that is how I have always put it, on the only remaining problem would be the number of washers. I never understood why your need 6, but as Will explained, it makes sense.
For the repair, I decided to try the JB Weld option first. It took three applications and filing to get it flush but the outer pulley half fits very tight now.
ausgezeichnet 08-16-2010 06:30 PM
Got everything back together. It took shims 5 on the inside and 1 on the outside. It is running great. We will see how long it lasts.
