-   -   What spacers for 7x15 wheels under SC flares (http://forums.pelicanparts.com/porsche-911-technical-forum/549015-what-spacers-7x15-wheels-under-sc-flares.html)
Shaun @ Tru6 06-20-2010 12:14 PM
I hope to have SC flares welded onto my 73 next weekend. I'm running 225/50/15s on 7x15 cookie cutters in the rear and want to pull the wheel out from inside the well. Right now they just tuck up inside the narrow body quarters with a lot of negative camber.
I've got longer studs to install and 1/4 inch spacers from another project, but am thinking I could add at least 1/2 inch and up to 1 inch to really fill-up the arch.
Anyone done this?
stormmaster 06-20-2010 12:59 PM
no spacer needed
James Brown 06-20-2010 01:23 PM
I went with 21mm rear spacers and 72mm studs. there turbo spacers and fill out the wheel wells good with no rubbing.
Shaun @ Tru6 06-20-2010 05:43 PM
THanks JB. Would you have any pics you can post?
I think I have 66mm studs to put in but can probably pick up some 72s on Classifieds.
Todd Simpson 06-20-2010 05:50 PM
Shaun-
Your 7's are et23 I would guess...8's are et11 or so. The 8's are a 1/2 inch less offset and a 1/2 inch increase in width on the outer edge.
So...a 1" spacer would put the outer edge of your 7's in the same place the outer edge of 8's would be. And we know 8's look good!
Shaun @ Tru6 06-20-2010 06:06 PM
Thank you Todd. Yes, 7" cookies are et23. A 1 inch spacer sounds great and I don't mind grinding/rolling the flare lip.
Would you know if someone like Weidman could weld-up 8s out of cookie cutters, they being cast wheels? Of course tire selection is nil, but that would be an excellent wheel for my car. Have also looked at these Campagnolo wheels.
http://forums.pelicanparts.com/uploa...1277085979.jpg
nineball 06-20-2010 06:32 PM
7x16 on the rear of my sc
http://i15.photobucket.com/albums/a3.../wheels002.jpg
same wheels with 23mm spacers
http://i15.photobucket.com/albums/a3.../wheels004.jpg
other side, stock
http://i15.photobucket.com/albums/a3.../wheels001.jpg
with spacer
http://i15.photobucket.com/albums/a3.../wheels003.jpg
James Brown 06-20-2010 07:57 PM
that's what mine looks like (only mine is the correct blue!!) The 72mm studs are a little long maybe 68mm would be better. But i'm using steel lug nuts for that "R" look!:rolleyes:
Shaun @ Tru6 06-21-2010 04:31 AM
Thanks for the pics! that's what I'm going for.
So it's possible I could just use my 66s and labor changing studs vs. a bolt on spacer. How difficult was it to get the old studs out? I imagine new studs going in were just socket over stud and C-clamp. What did you do?
tcar 06-21-2010 11:44 AM
Had 1.25" real hubcentric spacers w/ long studs and 7x16 Fuchs on my SC.
Was perfect, exactly like 8x16 Fuchs.
nineball 06-21-2010 01:44 PM
sorry, i was a little mistaken on my spacers. they are hubcentric, but they are 28mm, not 23, so 1.1" total spacing.
Shaun @ Tru6 07-12-2010 04:27 PM
Here's a 1 inch spacer with the SC flare on. bad pic, won't be able to get the other flare on until August unfortunately. Work always gets in the way of fun.
http://forums.pelicanparts.com/uploa...1278262283.jpg
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
