pedal brackets
Hi!
I need a little help. Here's the background... I acquired this 1977 911 about 6 months ago. At the time, the pedal cluster was completely rotted out, as well as the floor pan beneath it. I've just finished replacing the floor pan and have a new cluster to install. However, I'm not clear on how it installs. Our host advertises this pedal cluster support bracket, and a similar one for the gas pedal. ![]() Does the pedal cluster bolt directly through holes I would drill in the floor pan (have already drilled), or is this support bracket something that was used from the factory when the car was new? If the support bracket is something that was there before the rust worm struck, how does it install, and does it go above or below the floor pan? Thanks for any help you guys can offer!
‘86 Porsche 951 '69 Ford F100 '83 GL650 rat bike '17 F150 |
I would guess that if you flipped it over, the two studs would be the rearmost pedal cluster mounts and the two nuts would be for the throttle pedal.
It is installed underneath the new floor pans.
Sent from my iPad using Tapatalk |
That's what I needed. Thank you!
