Carerra Pulls to the right
I have a 1987 Carerra Coupe with 150k miles that I am restoring back to mostly original specs. As part of the restoration I replaced just about every front suspension component, including turbo tie rods, new standard ball joints, sway bar bushings, standard bilstein struts. I also went with poly bronze bushings, low friction control arm mounts, and a strut brace. The torsion bars were ok. The tires are 1 yr old with 4k miles. The corner balance is decent. I have had it aligned in two different shops and it still pulls to the right. It will change lanes to the right within 100-200 yards, depending on the crown of the road. It almost does better under braking, and I have new SS brake lines, pads, and fresh brake fluid. My mechanic loved installing the control arms, he was fascinated with how easily they moved compared to rubber mounts. He did comment that when he tightened the front control arm mounting bracket bolt that the condensor protective bar bolts through the right control arm bound up and wouldn't rotate freely, so he shimmed the bracket with a couple of washers until the control arm rotated freely. The alignment guy thought it could be the tires, my mechanic thinks I shouldn't use such a high performance component on a street car since race cars don't worry too much about a pull issue. Any suggestions would be appreciated.
Old 05-22-2010, 11:12 AM
First thing, replace the tires or just to double check if it is, swap them. If pulling gone, replace. Good luck. Steve
1970 911T SOLD
1989 3.2 Carrera
2013 991 Carrera S
Old 05-22-2010, 01:36 PM
I had the same problem. New torsion bars had been installed and one was binding. Still not sure how this happens, but now the car does not pull.
Hugh Lindberg
1972 911
1970 Alfa Romeo 1300 GT Junior
Old 05-22-2010, 01:53 PM
I had the same problem except mine was pulling to the left. Turned out to be a loose right rear wheel bearing.
Old 05-23-2010, 04:57 PM
rsa rsa is offline
rsa's Avatar
your front right pads may me dragging. Sometimes this happens with all the work you did on them. Pistons may not be retracking all the way in. Would also explain that it is better under braking.
Scott
77 911s
Old 05-23-2010, 05:28 PM
cliyde's Avatar
Having the exact same problem as you with all new suspension refresh: Turbo tie rods, ball joints, Bilsteins struts, torsion bars, and Polybronze Bearings. Car was professionally aligned and corner balanced by reputable P-car shop. Checked for caliper drag and there was some. Calipers were exercised which helped, but didn't correct the problem. Checked front wheel bearings adjustments, all within spec. Out of ideas, other than to recheck alignment. Any updates or luck in your search?
Originally Posted by klondike15 View Post
I have a 1987 Carerra Coupe with 150k miles that I am restoring back to mostly original specs. As part of the restoration I replaced just about every front suspension component, including turbo tie rods, new standard ball joints, sway bar bushings, standard bilstein struts. [/img]
G-Body 3.6 Transplant
Old 06-23-2010, 06:59 AM
Senior Member
Superman's Avatar
FWIW, my car is perfectly aligned and it pulls to the right. As it turns out, it is not properly corner balanced. it is not imbalanced by much. (LF + RR) - (RF + LR) = 180 lbs.
Mocha 1978 911SC. "Coco"
Old 06-23-2010, 01:07 PM
Goldfinger
Mattcamp's Avatar
+1 Tires.
1984-Carrera (pewter metallic)
Old 06-23-2010, 01:12 PM
AL Z's Avatar
I had a similar issue with my last 74 911 after I had a shop in louisville install rear adjustable torsion plates from elephant racing. After over a month and several trips back to the shop and twice to the alignment shop. The shop finally listen, to what I was telling them from the start. That the severe pull was initiating from the rear of the car. They finally looked at the install and found out that the right torsion bar was preloaded when they installed the plates, making the car pull severly to the right.
Needles to say, I would never go back to that shop again.
Hope this helps.
AL Z
Old 06-23-2010, 02:10 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by Mattcamp View Post
+1 Tires.
If they are not directionals, swap side to side (front & rear) and see what happened (hopefully pulling to the left)
Who Will Live... Will See
Old 06-23-2010, 05:40 PM
Zeke's Avatar
i.................. I also went with poly bronze bushings, low friction control arm mounts, and a strut bracegood choices.
he did comment that when he tightened the front control arm mounting bracket bolt that the condensor protective bar bolts through the right control arm bound up and wouldn't rotate freely, so he shimmed the bracket with a couple of washers until the control arm rotated freely.i don't like what i'm reading. The purpose of the low friction alignment washers is to alleviate this problem.
the alignment guy thought it could be the tires, very well could be
my mechanic thinks i shouldn't use such a high performance component on a street car since race cars don't worry too much about a pull issue.say what?? Race cars want to be better than street cars in this aspect.
hth
Old 06-23-2010, 06:27 PM
The crown of the road comment caught my attention. If on a multi lane highway and you are in the left lane with a crown to the left Does it drift left there?. What are the actual readouts from the alignment shop ?
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 06-23-2010, 06:40 PM
