My car won't start!
Any help troubleshooting would be greatly appreciated! It's '84 911 Cabrio, stock, with 50K miles. It's always run perfectly (at least since I've owned it 5 yrs), one day just wouldn't start. Turns over fine, no spark. Any ideas?
<insert witty title here>
Do a search for no-start. Not to sound like a smart-ass search nazi, but I know this has come up here a billion times. It's either fuel or spark you're missing, and checking to determine is fairly straightforward.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
I don't want to sound like a one hit wonder but an easy place to start is your DME relay located under your drivers seat. If you (or your cars previous owners), haven't already done this, it's time anyway (about $35). Cheers
83 911 Production Cab #10
![]() Quote:
This will either eliminate or point to an ignition problem.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
... to introduce yourself properly
![]() ![]() ![]() Welcome to the board. P.S. 3 Canucks replie in a row!!!
When you say no spark, have you pulled a plug and verified that it isn't sparking? Can you smell gas as it is cranking?
Agree with the above about the relay being a good place to start. Plus it is good to have one with you just in case you die by the side of the road. If you have spark but no fuel check the fuel pump, jump the fuse for it to a live contact and verify that you can hear it spin up as a quick check. I just had to deal with one of them myself a month or so ago. Welcome to the board and to beat the rush how about a pic of your ride so we can all drool. ![]()
88 Carrera Targa 04 Volvo XC-70 58 Harley Duo-Glide 96 BMW K-1100 LT |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Also, perhaps the flywheel sensors? Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 06-24-2010 at 10:25 AM.. |
I replaced mine before the old one failed, and then I tossed the old one into the glove box as a spare. Cheap insurance!
1984 Targa |
I haven't had a chance to log on in few days. Thanks for the replies; I did pull a plug wire and grounded a new plug, had my wife turn it over, no spark. There is a fuel odor in the exhaust after turning over so I'm pretty sure it's an ignition problem. Sounds like a replacement DME relay is the best place to start.
Thanks again for the advice!! |
JDale442
How you doooooin?????.....you just couldn't wait for me to get back to you could you mate?
Anyway, the relay is under the drivers seat as you originally thought.......just so you know!!!! Stacey is the cutest troubleshooter you're ever gonna have Mr......... BTW, my baby may be back with me this week....will send you pics!!! Mill B'Stard
Neil 1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic (X) [B] 2011 BMW X5[B] 'Success is not final, failure is not fatal. It is the courage to continue that counts' |
......oh and John........it's courtesy to post pictures of your little babies to introduce them to us all........
I had the same problem. It was one of the red fuses (3rd or 4th from the left when facing the fuses) that had slipped out caused by the lead wire screws becoming loose. Check this and you may have a fix. Since you have a fuel smell probably not the fuel pump being stuck.
'82 911 SC track car - SOLD '86 944 NA - SOLD '01 Boxster S |
OK, I replaced the DME relay tonight, no change. I did notice that the tach stays on zero when cranking over. Any more ideas?
Examine coil and power to it, lead from coil to distributor, cap and rotor..... other than those, it may be more involved....I'm not sure of all the conditions the DME needs to see before allowing power to go to the coil. If your starter is turning, you would think your engines grounding would be fine, but you should probably have a look. Sorry buddy, It is likely a very small issue, but I realize your 911 times a-wasting!
![]() Quote:
Before finding the actual problem, I end up putting 12 Volts (from the the rear fuse panel) directly to the coil and ran with that for a week. Post pictures... of you car, it always help to get more help.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 07-03-2010 at 02:39 AM.. |
jdale442,
if you get fuel but no spark you have effectively narrowed things down to the ignition system or maybe the flywheel sensors. Make sure the coil shows +12V at both sides when the ignition is ON but you don't crank. This will rule out a fuse. check the resistance of the secondary with an Ohmmeter. Also verify the rotor and distributor are in good shape. I suspect your DME could be damaged. When you crank the DME (not the DME relay) provides GND to one side of the coil for several milliseconds at a time. This generates the spark. You need an oscilloscope to verify this. I suggest you find a fellow Porsche owner close to you (where are you located?) who lets you swap your DME into his car or vise versa. Any 3.2 will do. This quickly tells you whether the DME is the culprit. Ingo
'74 Targa 3.6 (not stock ![]() I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2 - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
John
I think you can discount the fuel pump....this is from a post about a guy whose car wouldnt stay running when starting.... "First, the fuel pump is not supposed to run with the key to ON. It only runs when you crank or when the flywheel rotates with more than 200RPM. So no worries there." Mill B'stard
Thanks for the info on the fuel pump Mr. Neil. I'm going to check the coil as suggested; sounds like with ignition on, either terminal should have 12V. to ground. Anybody know what the correct resistance should be on the secondary?
OK, I checked the coil terminals with the ignition on, but not cranking over. I got a little over 12 volts on each terminal. I pulled the distributer cap, there was some minor corrosion but overall it looked really clean. I'm having some diffculty getting the cap back on, but i think it just takes patience.
John
I should get my little baby back this week complete with Bentley Manual. When I do, let's get to troubleshooting this thing and put it to bed!!!!! M B
Thread Tools | |
Rate This Thread | |
