Preferred pronoun:Maestro
Norm K's Avatar
Distributor Lockout Help
Posted on the 930 side but figure there's gotta be some MSD experts here, too.
So I've reached the point in what oughta be a simple project where the War Department is becoming increasingly impatient; seems I'm spending too much time in my garage ...
Installed an MSD 6530 programmable ignition and have ran it as a "regular" box until I sent it into MSD for warranty service (wasn't communicating with my computers). Got the unit back from a couple of days ago and, communication issue resolved, I figured now would be a good time to lock the dizzy and take advantage of the 6530's ignition and boost retard features.
I've spent a lot of time reading the various posts on the subject and things seem pretty straight forward. So I disassembled the distributor, locked the weights and mag/stator wheel (can't remember the correct nomenclature while I'm typing this), reassembled and reinstalled.
Started the engine and let it warm up a bit then checked the timing with a dial-back light. With everything locked at full advance I'm getting only 18.1 total degrees of advance, so I'm looking for another 11 degrees (euro model 930 = 29% total)
Distributor is installed with Z1 aligned, the rotor pointed right at no.1 and the dizzy mounting stud comes through the adjusting arc at about the mid-point.
I hate it when I can't figure things out and have to post, but here I am. Any insight and advice is appreciated.
Thanks,
Norm
When in doubt, use overwhelming force.
Old 12-26-2013, 09:44 AM
