hot air conditioning fan switch
The car in question is a 82 SC. All air conditioning system is stock, with parts having been replaced as needed. The compressor is still the original York and the system, with R-12, blows very cool....not as efficient as a modern car, but OK for what it is.
I recently cleaned up the thermostat switch because it seemed to not be capable of turning the compressor off. Everything went OK, but when I was running the system without the console in place with the thermostat and fan switches not yet in place, I noticed that the 3-speed fan switch was quite warm, bordering on hot.
Is this normal or do I have some sort of issue with the switch?
Thanks,
'82 911 SC
Old 07-13-2010, 02:37 PM
Anyone?
'82 911 SC
Old 07-14-2010, 09:22 AM
The only way the switch would get hot is if the contacts are dirty. The switch contacts are supposed to be a very small resistance. P = I^2 * R ~ 0.
If they get dirty and the contact resistance goes up the power dissipated is no longer insignificant.
If it feels hot I would bet simple contact cleaning is not going to fix it.
Rick
88 Cab
Old 07-14-2010, 09:25 AM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
Same thing happened to me, I redid the crimp connections, heat all gone.
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 07-14-2010, 04:40 PM
onemark's Avatar
Hi Steve,
Mine got really hot just before it failed. I think the contacts inside built up a bunch of resistance from arching. The replacement that I got (from our host) had a slightly different pin-out configuration that I was able to figure out with meter.
All fan speeds work well now....if only it would actually blow COLD!
Mark
When in doubt, right foot out.
Old 07-14-2010, 06:53 PM
D911SC's Avatar
I just had my shifter bushings replaled and the mechanic said the switch was scorched at the back. I noticed it had become quite hot as well. I am replacing mine as I assumed it was on the way out.
My first love - 1993 964 C2 Manual Coupe
My second love - 2021 Macan GTS
Old 07-14-2010, 07:44 PM
