A bit of tuning & maintenance
Hello guys!
Still having fun forth and back from work ;) I am however doing some maintenance to the car. One thing I notice, is that some times during engine braking or very light driving it shudders a bit. I've read some things about decel valve, could that be causing it? I am going to change, wires, plugs, oil & do a valve adjustment from the back anyway. Then to a bit of tuning questions.. I think the sound is a little bit tame. I have a US 3.0 SC engine, with original exhaust in place. I am not intending to drop the CIS or anything, since I will drive the car all year, even wintertime. I'm just looking for a bit more sound and perhaps a few hp more... Thinking exhaust, filter and maybe some timing changes... Good tips for nice parts to buy and stuff to do with a standard SC engine with CIS in place. What sort of power can one fetch this way? Anyone swapped in a more modern EFI system on an SC engine? Like Motronic for instance? A lot of sensors has to be mounted and stuff? I have a bit of experience with EFI, since I mounted Haltech e11v2 in my garage on my Maserati single handedly. Thanks! |
In my opinion, most SC's need to be largely disassembled, then reassembled using some fresh parts. Engine mounts, suspension bushings, etc. This makes the car feel more solid.
I like my Triad exhaust. Modern EFI systems are very popular. |
I have to assume they did what they where supposed to do then.. Anyone else have some tips on the issue I describe? Thanks a million for the exhaust tip. Looks fab. Do you have SSI headers etc as well? Cheers, Jarle |
i just put a dansk pre-muffler on my SC in place of the cat and love it. it got a little deeper at idle and maybe up to 2k but after that it sounds like normal. i doubt it did much in the way of adding hp but the car has enough to thrill me already.
| All times are GMT -8. The time now is 10:15 PM. |
