Oil line interference with stock crossover tube
I have a 1987 3.2 that came with a B&B exhaust and the associated change in oil lines. I would like to put a stock exhaust on the car so it can pass emissions. Problem is that the B&B supplied right angle oil line to the thermostat blocks the space where the crossover tube would connect to the cat. Has anyone encountered this in the past? If so, is there a simple fix or will I need to buy a new stock oil line?
Old 06-26-2010, 08:45 PM
Yep, you need an original oil line. Just pots a "WTB" add in the classifieds here.
1986 3.2 Carrera
Old 06-27-2010, 05:25 AM
Tags
oil line exhaust
