rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
Is this correct (sunroof question)?
Do I have the spring in the right place (i.e. below the pin)?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 06-26-2010, 09:31 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Yes thats correct but I'm not sure you have the clip positioned properly. The little tabs on the clip should be under the tabs on the sunroof side. It may be just the light.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 06-26-2010, 09:59 AM
1.367m later
KevinP73's Avatar
This tab
Old 06-26-2010, 10:06 AM
Immature Member
dentist90's Avatar
That's a good question, and timely. I just replaced my sunroof cables today, but have had my sunroof off a couple of times already. My spring just swings over the screws on the rear mount. It seems to me that you really have to strain that piece of metal to get it over that arm. And like mine, you have that little scuff mark on the sunroof that coincides with where the spring arm rests when it is just overlaying the screws.
My roof had the spring against the roof the first time I opened it up, but I'm not saying that is the correct position. I'm not even sure what that darn spring is for! Anybody know for sure what it's function is?
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 06-26-2010, 06:17 PM
mattmcginn's Avatar
The spring piece is positioned correctly in the photo, but the bracket is not.
What the flat, body-colored spring does is exert downward tension on the sunroof panel via the round bar (3mm or so that is attached to the sunroof cable ends) which keeps it from flipping upward before it is all the way forward. The Nylon pivots on the cable ends allow the sunroof roof panel to drop down instantly when the panel is moved rearward (due to the downward tension of the spring-not just gravity) as well as to rise into position when it encounters resistance when moving forward, and the springs counteract that to a degree.
If you don't put them that way, and are fooled by the little scuff marks on the roof, thinking (logically) that the scuffs indicate that the spring always sits there, the slightest resistance as the sunroof panel moves forward will cause it rise prematurely, scraping underneath the actual roof. Usually this does not occur if all is nice in the tracks and everything is balanced side-to-side, but let a burr get in there, and the roof will jack up and scrape. It is more of a problem on electric roofs rather than manual, because the switch is an on/off thing. (old BMW's had cranks with the same system, and you can feel the resistance better)
The scuff mark is where the flat spring sits when the roof is shut and the spring has no tension.
As was stated, the bracket "wings" needs to be positioned within the receiver tabs on the roof.
Many 60's-70's Golde sunroofs are built like this. BMW's of the era used the same system and many of the movable bits are interchangeable if you get in a jam.
Matt McGinn
1984 M491 911 coupe,
69 912 with 901/01 twin plug engine,
57 356 coupe
1972 Alfa Romeo GTV-stock/restored
Last edited by mattmcginn; 06-26-2010 at 08:00 PM.. Reason: adding additional information and correcting poor syntax.
Old 06-26-2010, 07:44 PM
