Ford Explorer = 911 (rear brakes anyway)
So I am waiting to get my rear tires mounted and I pick up a magazine to pass the time only to find an article that is talking about a rear axle that states:
"The design of the Ford Explorer disc brake is beautifully simplistic. The hat-style rotor slips over a miniature drum brake assembly" Car Craft (Jan 2002) There was a pic that looked all too familiar with the article. just made me laugh.....the next thing you know they will have independent rear suspensions.......oops! they do
don't most rear disc brakes work that way??
PRO Motorsports
No. Actually, most use a screw-type caliper piston which utilizes the existing pads to grab the rotor. The German and Swedish cars usually use the drum-inside-rotor style E-brakes.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Swedish cars?
Hell no...Saab 900C handbrake works on front rotor calipers (!)...Saab 9000 utilizes handbrake wire that works on back rotor calipers. It's first now with Saab 9-5 that they started to use conventional drum-inside disc. Volvo used drum as far as i remember tough. Altough this approach reduces unsprung weight and is more simple, it's hard to make good E-brake that uses ordinary disc-style caliper beacuse drum-pads have a tendency to "dig-in" and thus lock the wheel.
Thank you for your time, |
Well, then Vette's must have something going for them since they also use a small drum brake inside the rotor hat. Since it takes a pretty sizeable rotor for a drum brake setup to fit inside the hat most of todays cars wouldn't really have room. I've heard that it's difficult to get a mechanical setup to work well on discs, but I guess time and technology have overcome that problem.
PRO Motorsports
I was referring to Volvo's. Luckily, I've had little experience working on Saab's. About as ass-backwards of a car ever built.
...after working with Saabs Porsches suddenly looks pretty simple and straightforward. :-)
But they do have best turbocharged engines in the bussines...
