Milo2361's Avatar
GT3 style - homemade...
well i really didnt feel like springing the 700 for the M&K although it would have been nice, i used a Borla XR1 racing muffler, one dynomax 180º pipe, some random pipe i had laying around, and the skills i learned in High School shop class. I think i came out pretty good.
really tough fitment, as i had to bring the exit from the cat back towards the drivers side a bit, then around going into the muffler. the outlet was easy, and i custom fabbed the dual tip myself because anything i could find on the internet ended up being too long or the wrong sizes so i didn't even bother.
before:
after Fabrication:
on the car:
total cost of $135. Id like to think i did pretty good.
1998.5 Ram 2500 Cummins
Old 06-22-2010, 07:02 PM
And I will be the first to say "You did good".
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 06-22-2010, 07:10 PM
Milo2361's Avatar
if i can find a decent video recording device i'll post a clip... sounds real good. kinda raspy, deeper sound - pretty loud but not outrageous. a little bit of drone from idle up to about 2200 rpm, but after that it goes away. i dont know too many who like to run their 911 down that low anyway.
Old 06-22-2010, 07:16 PM
Under the radar
Trackrash's Avatar
Is that stainless steel? What type of welder did you use? You must have had an awesome shop teacher.
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-22-2010, 08:00 PM
Milo2361's Avatar
the muffler is stainless, but the pipes are aluminized steel - - i feel i need to put something on them to keep them from rusting but the BBQ paint i used on the last creation didn't work.
the welds on the tip look good cause i ground them flat incase they would still be in view . its a gasless flux core wire welder. very similar to mig minus the gas i guess. hard to keep a good bead because of it, and butt welding pipe to pipe isnt the easiest. the hardest part was welding the muffler to the pipe due to the differences in the metal thickness. they're a little ugly but sealed - the most important part. I am in the process of fabricating a bracket for more stability to put on the stock muffler bracket.
Old 06-22-2010, 08:08 PM
Milo2361's Avatar
heres a couple of photos of the muffler when i got it.
it was SUPER heavy when i got it, weighing in at a whopping 9 pounds.
Old 06-22-2010, 08:22 PM
Danny_Ocean's Avatar
I'd have to guess the hardest part was welding that shovel handle to the unit...
Old 06-22-2010, 08:34 PM
Milo2361's Avatar
wow didn't even notice the placement of the picture! good catch
Old 06-22-2010, 08:40 PM
At first glance, I thought you were using that as an exhaust hanger (you did say "home made"...).
Old 06-22-2010, 08:42 PM
flat6pilot's Avatar
Most car shops carry high-temp header paint. 800°F+ I use it, it seems to work good. No signs of rust yet.
Oh, and nice job!
Kyle
1980 911sc 3.2 Turbo, 930 Trans
2006 BMW 330i 6mt (DD)
Old 06-22-2010, 09:45 PM
a.k.a. G-man
Geronimo '74's Avatar
looks great! Good job!
dimensions?
Angles?
Diameters?
Old 06-22-2010, 09:55 PM
schumicat's Avatar
Griot's Garage sells high temp paint that holds up very well.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 06-23-2010, 05:14 AM
3 restos WIP = psycho
kenikh's Avatar
Very well done! That Borla muffler is intriguing, since it isn't chambered. Nice find.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-23-2010, 10:25 AM
Elombard's Avatar
You need some SSIs and do 1 on each side.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 06-23-2010, 02:12 PM
Milo2361's Avatar
ideally i would have gone with SSI's and an M&K 2 in 2 out version, but thats a fairly large amount of money i dont really have to shell out on it. throttle response is a little better, or atleast it feels like it - - - it for sure sounds like it. as for Dimensions, all i can say is the diameters are 2 1/2 inch all around, and the muffler case is 12 inches long. the muffler has two 3 inch stubs of pipe which i had to cut off to about 1/2 inch. the pipe coming from the cat in to the muffler is a homemade concoction of a 30º slant cut on both sides of one stub, and a 90 that sort of somehow slipped over it, then i heated it and bent it down to weld it so i didnt have to bridge a gap. the diameter at that point isn't quite 2 1/2 inch but i don think its making too much of a difference.
made my bracket - an old electric fence post welded to a piece of flat iron, bolted to where the old A/C mount was and hoseclamped the post stub to the muffler.
Old 06-23-2010, 07:47 PM
Looking good Milo. BTW I had a buddy in college from Bayard. Eric Siegfried--great guy! I was there for his sister's wedding years ago--nice little town!
1980 911SC Targa 3.6L
Old 06-23-2010, 08:31 PM
Milo2361's Avatar
was his sister Kara Siegfried? Her mom was my 3rd grade teacher
Old 06-23-2010, 09:20 PM
OCD project capitan
BigD9146gt's Avatar
Nice work! Your next assignment is to make a duel exhaust for a GTI that has an R32 body kit on it... please don't ask me why anyone would want to do this
Don Welch
'73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper.
Old 06-23-2010, 11:54 PM
Wavey's Avatar
Nice work Milo, I like it!
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 06-24-2010, 06:54 AM
Milo2361's Avatar
i painted both front and rear valences black - the rear because i didn't want to chop my original one, and the used one i bought was white, and the front because it was BADLY rock chipped. upon stripping the front i discovered the PO(or one of the PO's) did a TERRIBLE bondo job where it looks like he hit a curb... I sanded it as smooth as i could get it in 3 hours - almost perfect but not quite... not like its clearly visible anyway. wish i could figure out how to get the back valence black under the accordions to make it match front and back better... i still think it looks all right.
wish i could find a CHEAP valence for the rear that curved around on both sides so i didnt have those holes that are meant for a dual exhaust on the sides... anyone have any ideas?
Old 06-28-2010, 03:34 PM
