Removing Windshield Adhesive
Good Morning,
Just spend the evening removing the old shield and getting the new one ready.
Read allot of the posts and found some VERY helpful tips.
I'm now trying to clean up the window channel from the old adhesive. What have
you guys used to remove this stuff? Any home remedies or just the caustic sprays?
Also I've read about using adhesive or not to reinstall. Whats in there now looks
factory installed . Your views?
Thanks to all that have posted their installs you have made things allot easier.
Joe
Old 06-27-2010, 05:49 AM
Razor knife, lacquer thinner, then POR.
Old 06-27-2010, 06:46 AM
Pre Registered
tchanson's Avatar
If this is a 911, there should not be any adhesive involved at all, as the glass is held in by the seal only.
As far as removing what is there now, I would suggest 3M General Purpose Adhesive Remover, which is generally safe for cured paint.
Tim
Old 06-27-2010, 08:18 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Cleaner
Here's another option.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-27-2010, 09:18 AM
kodioneill's Avatar
If it's silicone, I used a product from RPM technologies for removing silicone, worked and won't hurt paint.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 06-27-2010, 11:02 AM
Metal Guru
911nut's Avatar
From the 964 forward, adhesive between the body aperture and the gasket is used to hold the windshield in place. Makes it tough to remove the windshield without breaking it.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 06-27-2010, 11:04 AM
Mitch Leland's Avatar
Removing W/S Sealant...
First off I wouldn't use Lacquer thinner, that's pretty strong stuff left unattended on most paints or interior surfaces. Regarding the use of a razor knife, I would try and stay away from scratching and tearing up the paint around the window channel to prevent rust in the future. Certainly using POR 15 to treat any bare spots is a good idea.
I used enamel reducer and a plastic putty knife and a lot of elbo grease. Cover up your dash and fenders and have at it... I had a combination of several sealants. I think it's important to clean up the window channel so the new gasket lays in and seals well. I found that I have less air noise now. Also the original factory gasket covers and installs much better than the after market gaskets. So this is one place "not" to cheap out...
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 06-27-2010, 02:42 PM
Pre Registered
tchanson's Avatar
Which is why I limited my comments to 911's, not 964's or 993's.
And for the record, post October '88 build date '89 3.2 Carreras that came from the factory with the 964 windshield and trimless seal did not use any adhesive either.
Tim
Old 06-27-2010, 04:07 PM
Zeke's Avatar
Tim
However, some installers are using sealant because of "insurance" purposes. I first faced this in 1994 when I last had a windshield replacement company do my '77 Targa.
Apparently they have seen how the front glass will pop out way too easily in a crash exposing the occupants to potential and additional injury.
Old 06-27-2010, 04:31 PM
SP2 SP2 is offline
SP2's Avatar
The Porsche workmanual (the large 2 volumes) says to put a sealant between the body and the rubber gasket. There is even a photo of this. These were early cars.
Old 06-27-2010, 04:53 PM
