-   -   CIS to EFI Conversion Information (http://forums.pelicanparts.com/porsche-911-technical-forum/55049-cis-efi-conversion-information.html)
Fishcop 12-24-2001 04:09 AM
Hi guys, although this does not relate to me or my particular car, I do remember a thread recently that was discussing various CIS to EFI conversions.
Well I was surfing away tonight on mostly Australian sites and came accross this lot. No idea about them other than what they have to say for themselves. Makes interesting reading though. I hop it is of some use to you.
http://www.pem.com.au/porsche.htm
Merry Christmas
beepbeep 12-24-2001 06:30 AM
thank you!
Oldporsche 12-24-2001 06:43 AM
This looks very good. A clean reversable modification that results in better power and provides no bad long lasting side effects.
Good luck,
David Duffield
RarlyL8 12-24-2001 08:43 AM
Thank you John!
I have been sourcing parts to build a system identical to this one!
Stands to reason that someone would have it available, I just had not found it.
I couldn't get them e-mailed fast enough!
sewell94 12-24-2001 12:04 PM
I am also interested in this kit for my 76 930, I email them for more details, would anybody else be interested in seeing if they would give use a discount for a group buy???Thanks
5axis 12-24-2001 03:57 PM
1 Attachment(s)
Okay, you have my attention too! I am wondering how this compares to the 3.2 manifold and Haltech or ?? system. I have to admit the plumbing for the intercooler looks top notch. $$$?
Merry Christmass to all
beepbeep 12-24-2001 04:17 PM
5axis:
Haltech (or SDS) + 3.2 manifold is probably better than this setup.
930 engines are "downtuned" by strangulation of intake ports to 27mm in order to boost gas speed and thus raise low-RPM torque.
930 heads ported to 32mm and properly mached with 3.2 intake probably flow better than original setup and should deliver better torque.Unfortunately it's lot's of work. This system looks much more bolt-on. I'm just a bit puzzled with dyno-graph saying that original 930 delivers 206 WHP (Dynamic WHP??).
I also mailed asking for price...In my eyes, Stage I shouldn't be more expensive than 2000$.
Is Stage I incuding both fuel and ignition ECU? I couldn't figure it out from sketchy info on the page.
Let's check the price, I'm interested in group buy too...
Yargk 12-24-2001 05:17 PM
206 shouldn't be too far off for rear wheel hp. With a 15 percent driveline loss, that comes to about 240 hp at the crank. Stock US spec 1976 turbos are supposed to make 245 DIN, although I've heard as little as 234 net.
Flying in the face of all this, I was pretty familiar with a 76 turbo for some time and it seemed only the exhaust was changed, not to a performance model, just the thermal reactors were changed to something more euro. So I would think the car would make 260 at the crank, like the euro models. I had it dynoed, and it made 243 at the wheels which translates to 285 crank hp. Go figure.
RarlyL8 12-24-2001 09:20 PM
I'll need to know how much power the system can support.
My present mods (with CIS) should be upward of 350HP at the crank. I wouldn't think this to be a problem. Looks like a good system.
My view is that the 3.2 intake is not a necessary mod for a 930. The standard CIS intake manifold supports the same 400+HP that the CIS is capable of delivering.
beepbeep 12-25-2001 06:13 AM
rarly:
This is a EFI setup with variable FRP. As long as injectors are >350cm^3/min , this system should be good for >450HP @ 1:12 lambda...all this @ 3 bar system pressure. So i don't think it's a issue unless they fitted it with really small injectors which i doubt...
That's one more question that needs to be asked ... how big are injectors?
5axis 12-29-2001 08:07 AM
A related thead:
Has anyone had a response from these guys yet?
RarlyL8 12-29-2001 09:36 AM
I'm glad you asked that, I was about to.
I've e-mailed away - and not one response.
We can build this system ourselves anyway.
sewell94 12-31-2001 01:11 AM
The reason this option looks appealing is that you don't have to use the carrera intake, why not get a motec or sds and just use the stock intake and put the injectors in the stock holes like that kit, BTW i didn't get a responce from them either, I WANT EFI, but am on a budget, i would to find a cheap way to put efi on.
