-   -   Primer Question (http://forums.pelicanparts.com/porsche-911-technical-forum/55051-primer-question.html)
warment 12-24-2001 05:32 AM
Primer Question
I recently stripped my 73 down to bare metal using Aircraft Stripper and a lot of sanding and hard work. Anyway, since I don't have a garage, I applied spray can primer to the entire car one section at a time to prevent "flash rusting." I was told that I should have been using an Epoxy Primer to cover the bare metal prior to using regular primer.
My question then is, when I take the car to the body shop to get it painted, will they remove the spray can primer, then apply Epoxy primer, then re-primer before the paint process? Thanks for your thoughts...
Bill
TargaEuro 12-24-2001 09:27 AM
If you dont ask them to strip the primer they may just prep sand it . I dont see how they can warranty their paint work if they dont remove the spray can primer. I would ask them to strip the primer first (for extra cost I would assume) and they will usually lay down a coat of self etching primer then hit it with high build primer it may be epoxy, depends who's products their using....TargaEuro
john walker's workshop 12-24-2001 10:15 AM
spraycan primer is porous. it does not protect the metal from moisture. i would strip it again and apply DP 90 to the bare metal.
