Removing Pedal Cluster in 87 911
Hello to anyone who has any experience here.
I want to rebuild my pedal cluster but I don't want to get into a bigger project than anticipated. Bentlley page 301-15 seems to say that the clutch master cylinder needs to be removed to do this. Is this correct? Can't one just remove the pedal cluster without removing the clutch master cylinder? It sure looks that way. But, appearances can be deceptive.
Thanks for any help!
Greg
Greg Jetson
1987 Carrera Coupe Venetian Blue
1984 Carrera Targa Slate Blue
1979 911 SC Slate Grey (sold, but it irrevocably launched me down the path)
Old 07-01-2010, 02:35 PM
Packy's Avatar
It's kinda a pain in the ass. Why do you want to do it?
(1) '77 Chassis and '79 SC 3.0 project car
(1) '79 911SC 3.0 Widebody SC
(1) '15 Ford F-150 4x4 3.5TT
Toluca Lake, CA
Old 07-01-2010, 03:02 PM
Packy's Avatar
and if I remember correctly there are two linkages to the MC from the pedal cluster. I think the clutch is not that bad cus its a ball a socket that just pops off. i could be wrong though.
Toluca Lake, CA
Old 07-01-2010, 03:04 PM
Thanks Packy.
I want to take out the pedal cluster to restore it primarily by putting in bronze bushings. It looks simple but I know with Porsche that can be deceptive. I would like to do it without removing the clutch master cylinder. But Bentley's seems to say no.
If anyone has removed the cluster on a 87-89, I would like to here how difficult it is.
Greg
Greg Jetson
Old 07-01-2010, 03:36 PM
geoz's Avatar
I'l lhave t subscribe this thread.
I was looking at the pedal cluster myself because the clutch pedal made some noises but to my untrained eye it seemed like a rather interesting job.
cheers
hg
1988 911 Cabrio
Old 07-01-2010, 04:15 PM
NO LIFT's Avatar
Me thinks you can just remove the linkage pin between the pedal and the MC?
2003 996 Carrera
gone but not forgotten '88Carrera '96 993 '89 951
Old 07-01-2010, 07:04 PM
Diss Member
Quicksilver's Avatar
The clutch master cylinder connects directly to the pedal assembly. Yes you want to remove the clutch master because otherwise you would need to disconnect the 2 hoses, plug them, and then bleed the system when you are done.
If you have small hands it is pretty easy. With big hands it isn't too hard though. The little things that are irritating are trying to reach the throttle linkage ball joint, loosening the 2 nuts on the clutch master, replacing the clutch master boot, having to drop the steering rack splash pan to get at the 2 bolts under it, and getting the clutch helper linkage to stay in the up position when you are putting it back together. (When it falls down it jams the pedal.)
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 07-01-2010, 11:02 PM
Diss Member
Originally Posted by gr jetson View Post
Thanks Packy.
Greg
I'm not aware of any bronze bushings being available for the G50 pedal assembly. All the bushings are very thin plastic and all the part numbers shown for it in PET are plastic.
Old 07-01-2010, 11:05 PM
