oil bypass modification
Can someone tell me do i really need this. My motor is a 2.4E and will be a weekend driver, thanks John.
Old 06-24-2010, 05:23 AM
tobluforu's Avatar
Dyeing to hear about this mod?
Old 06-24-2010, 05:25 AM
If you're opening the crank case and adding a bigger
oil pump then you should do this mod while you're in
there.
Don't forget to get the different pressure relief pistons
or it won't work.
andy
Old 06-24-2010, 05:54 AM
Home of the Whopper
The mod reduces the amount of oil in the case, which puts more elsewhere in the engine. It takes about 5 minutes to do and only cost about $1 in material. So why not do it if you are splitting the case?
Even with the old pump it is still worthwile to do. But no, you do not NEED to do it.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 06-24-2010, 07:45 AM
ajwans,BK911 thanks for the input i will end up doing it. john
Old 06-26-2010, 10:15 AM
BURN-BROS's Avatar
In addition to the bypass mod you should do the following (if not done already):
source an aluminum SC pump. not mandatory but will be a much better pump down the road. The mag pumps will distort over time causing pressure loss and binding.
time cert the 5 rear perimeter studs. These tend to pull threads so tackle them while the case is apart.
case savers. If your case does not have them already it is wise to have them done while the engine is apart.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 06-26-2010, 10:39 AM
Can't believe how simple it is... Check out this video
Neil
'73 911S targa
Old 07-03-2010, 04:33 PM
Aaron, and Neil thanks, looks easy enough. John
Old 07-04-2010, 02:01 PM
