Would '76 rear torsion bars fit a '71?
Hi,
Is there a significant difference between the original '71 rear torsion bars and the '76 ones? (Except thickness) Are these 2 interchangeable? Thanks for your help! Hessel
'71 911 T Original Burgundy |
Mark S
They are interchangeable. No difference except diameter as you noted.
All are interchangable until you get to the G50 cars, theyre different.
Bruce |
I don't even think the diameter was different...I thought they were both 23mm?
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Senior Member
Make sure you move them side to side, right side to right side.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Mark S
Keepin' it Simple...
1965-1977 non-turbo 911's all used 23mm bars in the rear.
-Doug 1968 911R Clone; 11/07-?? (forever the project car )1978 911SC Midnight Blue Metallic Coupe; 7/05-11/09 (so long impact bumpers) 1973.5 911T Sepia Brown Coupe; 9/98-8/99 (went to a great home) 1973.5 911T Gulf Orange Targa; 5/97-11/02 (went back to Germany) |
