-   -   Which headers with PMO ITBs (http://forums.pelicanparts.com/porsche-911-technical-forum/551370-headers-pmo-itbs.html)
shahram 07-04-2010 05:21 AM
hmmm, i am planing to use a set ot PMO EFI ITBs on a 993 3.6 that we are rebuilding.
What size of headers and which kind of headers would you guys recommend to use with that combination?
DW SD 07-04-2010 07:40 AM
I might wait for Bill Verburg to chime in, but suspect 1 7/8" primaries will be the recommendation.
Doug
shahram 07-05-2010 11:15 AM
Thanks doug,
I also was thinking to get a 1 7/8" but PMO recommends to use 1 5/8 or less with EFI ITBs. I don't know why. I guess the stock heat exchangers are 42 mm or something around 1 5/8".
Steve@Rennsport 07-05-2010 12:01 PM
What cams are you using????
Header diameters depend on operating RPM range as much as displacement. :)
shahram 07-05-2010 12:03 PM
Hi Steve, for now I leave it with stock cams. The car is used 80% street and 20% track or DE...
what do you think?
Steve@Rennsport 07-05-2010 12:36 PM
what do you think?
Thanks for that key piece of the "puzzle". :)
JMHO, but based on a lot of dyno work, 1 3/4" & 1 7/8" headers are FAR too big for a 3.6 with stock cams and simply kill the low end power without a payback near redline (6750 RPM). Those big headers are fine for engines operated to 7500 RPM and beyond.
1 5/8" headers, properly made and with the right muffler, will make a lot of power in the operating range of stock or RS cams.
When or if you decide to change cams (and a lot of other internal modifications), sell the smaller header for the bigger ones that are appropriate for the engine's configuration.
shahram 07-05-2010 12:53 PM
Thanks Steve for great adivse. I have to contact you soon anyway to figure out the best way for the ignition and engine management system.
Steve@Rennsport 07-05-2010 03:06 PM
I have headers, too,....:) :)
