-   -   Proper location for rear view mirror installation (http://forums.pelicanparts.com/porsche-911-technical-forum/551494-proper-location-rear-view-mirror-installation.html)
SCWDP911 07-04-2010 08:52 PM
I found one thread while searching (http://forums.pelicanparts.com/porsche-911-technical-forum/105503-rear-view-mirror-location.html). I need to verify the proper location of the rear view mirror for an SC. My mirror broke off and I had ot replace the windshield. Not complete sure where the sucker goes now.
tcar 07-04-2010 10:25 PM
Took me a second attempt.
Right at the bottom edge of the shading, but in the shading.
If it's lower, you can only see the road right behind the car.
Too high and it interferes with the visors. (I have Carrera visors).
I used the adhesive when I put it on, but was able to remove the mirror by holding a lighter (leave it mounted on the puck) under the base of the mirror. Gently push up on the mirror. It pops off after 30 seconds or so. That's what my windshield 'professional' did.
tom.stiller 07-10-2010 10:15 AM
Excellent tip with the lighter...I mounted mine too high and I was wondering how I was going to get that sucker off of there. Worked like a charm.
SCWDP911 07-10-2010 10:28 AM
so on an 83, is it the adhesive tape, or a glue?
snbush67 07-10-2010 11:40 PM
It goes on the windshield...on the inside. SmileWavy
...couldn't resist.
I just put mine on with mirror adhesive that you buy at auto parts stores. It is the best I think, dries clear. I did mine with one tube. It comes as a small kit with a pre wipe cleaner for the glass.
Good Luck on your trip,
Shane
SCWDP911 07-11-2010 07:43 AM
...couldn't resist.
Shane
Ohhhhhhhhhhhhhhh, on the inside!?!?!:eek:
msublett 07-11-2010 11:34 AM
Rearview mirror? What's that for I never look back!
UrQuattro 07-11-2010 11:50 AM
Om the 83 it's glue.
Those pads are awful. They are just thick enough to let the mirror shake in the most irritating way.
Michael
wwest 07-11-2010 02:26 PM
You might think about going to Ebay and purchasing a self-dimming mirror with map lights incorporated. Makes a big difference in allowing a passneger to read maps with little or no light interfering with the driver's vision.
