Question power door locks
i want to install power door locks on my 1981 911sc. Is it possible? If so, where can I purchase?
Old 12-24-2001, 08:20 PM
Wink
I did power door locks on my '77. Aftermarket stuff didn't fit good enough. I used stock lock motors to 2 Bosch relays then used control from Viper anti-theft for remote open/close. Better to rebuild window mechanism/seal while you're in there. The lever from motor to locking mech. some times breaks at upper fastening point. I drilled it out and used screw with double nut. You have to get in there and see what you are dealing with. Simple but time consumimg. Stock central locking is big bucks and big headache.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-24-2001, 10:18 PM
dickster's Avatar
i did a search and came up with some from performance products ($96) - got good review from a thread.
just ordered mine!
richard
Old 12-27-2001, 09:33 AM
Cool
IMO...the Performance product is a quality item. Only problem is the mounting of the lock motors is different than stock, at least it was on my '77. Also there is not a remote/beeper in your order. I did not like how the motors would be installed in my doors. Good Luck...
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-27-2001, 09:47 AM
