So Pelican brain trust - how do you remove this?
Can's seem to find the solution.
Does it have a thread? Heat? Vice grips? http://forums.pelicanparts.com/uploa...1278472343.jpg |
Grinder and a cut-off wheel... :D
it is not threaded; its cast in place at time of manufacturer.
You want to remove it to upgrade to the later sway bar bung? Not going to happen. You will need the set up from weltmeister or tarrett / elephant for 1977 and older models |
Or later arms with threaded ball attachment.
Thanks for the replies - already have the Tarrett so good to go.
Please post photos of the install. How does the attachment to the spring plate differ from the Weltmeister?
| All times are GMT -8. The time now is 11:33 PM. |
