brake booster
do I need one? I broke mine in an accident and was looking to get another, they are $650 dollars
. I'm sure I could get one used but seriously, WTF? Can I just go with a larger master cylinder. I have not really looked into this so any thoughts would be helpful.-P
(1) '77 Chassis and '79 SC 3.0 project car (1) '79 911SC 3.0 Widebody SC (1) '15 Ford F-150 4x4 3.5TT Toluca Lake, CA |
I have a complete assembly (body, MC, booster, reservoir) that I was thinking of selling off a 78 SC but after I saw the replacement costs I figured it can't hurt to keep it. I won't sell it parted either way.
Gary R. |
Well, that doesn't help any.
abit off center
You can run it as is for now without the booster hooked up, just takes a bit more leg then add the booster when you find one. We have been running a long time without the boost hooked up.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
awesome, that is the response I was looking for. Thanks cgarr.
abit off center
Here is the setup after we added the electric vacuum pump to the booster. It does help a lot but we are getting old too. You young guys should not have any problems. We had to use the electric pump because we are running carbs and cannot get enough vacuum to operate the booster.
| Tags |
| booster , brake booster |
