911 sc heather blower troubles
My motor blower - right in engine compartment- stopped to work, 25 amps fuse ko.
Automatic control switch is ok, changed 2 years ago using a good second hand part. Loacal Electric auto repair shop told me that was not possibile to fit the motor, so i was thinking to buy a new one,supplìed with black shell. Before i decided to dismantle the assembly. The work is not difficult, be careful to not damage the big black plastic inlet from motor vents and the two corrugated carton alluminium tubes . When dismantled i found an erratic bolt touching the circular air rotor, so rotation was slow. The rotor is fixed to motor shaff with a 13 mm nut, that was not easy to remove. After treatment with derusting oli, i made at the top af the shaft a cut so a flat screwdrriwer avoided rotation. The bolt was fixed with a new hand made square nut, so the circular flange was fixed to the clindrical case of the motor. Then i appliied some silicone black gasket to avoid loosing of square nuts. Reinstalled, works wery well. ![]() ![]()
Nice repair and write up.
1988 Carrera
That motor is not cheap. Very nice save. Thanks
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
