how to test ignition switch?
Turning the key in my 88 Carrera, nothing happens - no lights, and no start. The last time this happened (10 years ago) it was the ignition switch. The battery is fully charged.
I have done a quick search but could not find anything about the correct testing procedure for the ignition switch. Bentley explains how to remove it but not how to test it. I assume I need to first test for power going to the ignition switch. Could someone give me sequence of steps to follow? |
To test the switch, use the aforementioned electrical diagram for reference. ID the circuit from fuse box to switch. Use a voltmeter to probe at various access locations in the circuit and different switch positions to confirm source voltage exists. Do this before chucking a good swtich. Hope this helps, Sherwood |
Thanks for the advice Sherwood.
Browsing through the forum again I found a post from someone who had the same problem, and it turned out that the electrical plug from the ignition switch into the firewall had become detached. I checked my car and thats exactly what it was. Praise the Lord. Second time in 6 months that I have disabled my car by accidentally disconnecting a plug. Last time it was the plug for the CHT sensor in the engine compartment, and the engine would start and die ... :rolleyes: |
Good catch. This forum is an invaluable resource of 911 info.
Sherwood |
| All times are GMT -8. The time now is 09:50 AM. |
