Platinum Member
After you lifter 1 side, you could have lifted the other side, and get the rear up, level, and on jack stands. Then lift the front from one of the front torsion caps.
Just go slow, and think. |
i have gotten to where i hate to do anything under the car just because it IS such a pain to raise it. i drive it up on 2x6's then one jack under the engine, put it on stands, then raise the front.
i like the 2x6's on there sides idea. might look into that more. i was thinking of some way to have a full drive ramp of some sort that was safe. my volvo is even hard to raise. i have to lift the front about 1/2 an inch to get the jack under. i had a set of metal ramps that someone gave me and i dont have a car that can clear them.
86 930 42kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 05 BMW 330CI 130K:: [_ ![]() 08 VOLVO V70 190K:: [_ ![]() 90 B2200[__] RUNNING:[ ![]() ![]() |
83 911 Production Cab #10
Time for a Scissor lift...
I know the felling, I only screw around once to remove a flat tire and I had enough... Check Post #13
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Nineball says:
Tom |
![]() Quote:
Only the top one need to be 2X12. The one under was 2 2X6 (a lot cheaper). I saw picture of you (and your wife) fleeing Canada when you got the car... so 100 Lb should be a piece of cake ![]() ![]() ![]() J.J.
Your prayers helped but this is driving me nuts!!!
The car rode up on the 10'x2's very nicely. (I had stapled some of that rubber cupboard liner material from the Dollar Store on the bottom to lessen slipping). But now I couldn't get the floor jack under the lifting point without putting the front wheels of the jack up on the boards. Front floor stand went under just fine but the rear torsion bar jackstand location is about half way across the board. I could put another couple of pieces of wood right next to it, but one really need to remove the boards after the car is jacked up. A 12" board that JJ suggests would have only made matters worse for my setup. JJ just needs to raise the car a few inches to get his sissors jack underneath. What am I missing here?! Tom |
1980 911 SC
Life's a Beach Last edited by sailchef; 07-10-2010 at 12:17 PM.. |
Sailchef, that's too easy!
![]() tpr |
1980 911 SC
Shelving.
Life's a Beach Last edited by sailchef; 07-10-2010 at 01:17 PM.. |
Well, it's back to square one!
I shortened the boards to about 2' each and notched in a ramp. So with a board in front of each wheel gave her a little gas, then a little more and wham!!! I blew the left rear board 15' into the driveway!! How's that for torque?! Fortunately nothing was damaged. So the board thing just isn't going to work. (I could maybe figure out a way to bevel the leading edge of each board step. ![]() My Harbor Freight Low Profile Floor Jack fits nicely underneath the engine so I'll prep for an engine lift. But am concerned that when the rear is lifted the jack won't fit under the front RS dam. This is never gonna end. Tom |
Platinum Member
Modify my post above by putting 1 or 2 pieces of 2x10 that you cut under the front tires. Then after the back is up and level, jack the front. The blocks under the tires will let you get under front spoiler.
Be careful, go slow. |
Just use boards to roll up with the fronts only. Jack up the rear by the engine case. Once the jack stands are on the rear move to the front with the extra couple inches of clearance you have from the boards it should be a peice of cake.
-Todd '82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs. Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete |
Platinum Member
You may also be interested in a new low profile jack. Our host carries the AC Hydraulic jacks which look nice and are only 3.5" high to slip under almost any p-car.
1980 911 SC
The trick is to stop before you go over the other side. A 2x4 across the front of each one should keep this from happening. This is getting interesting now.
Life's a Beach Last edited by sailchef; 07-11-2010 at 12:42 PM.. |
Fellow Pelicans: Success!!
I have borrowed ideas from a bunch of you and it worked just fine. I put the maximum bevel on the front of each board (2 each 10"x2" screwed together) with a 1' platform before the rolling tire hit the next board. I avoided lifting on the engine, but used the lifting plate on each side the car where the emergency jack inserts go in. I was able to place jacks under front and rear torsion bars one side at a time and repeated the process to lift the rear a little more to level the car. You can see it all in the photo. One of the front end ramps is at the right of the photo. Thanks a million! Tom Tom ![]() Last edited by grizzfan; 07-11-2010 at 02:16 PM.. Reason: complete a sentence |
Thread Tools | |
Rate This Thread | |
