1988 Porsche 911 frozen caliper HELP!
Hi All,
I just started rebuilding the brake calipers on my 1988 Porsche 911 Carrera. I have done many different brakes in the past but I have not come up against a totally stuck piston in the caliper assy.
I first tried 30 psi and one side came out to the wood block that I have there. The other side would not move. I put it back into the car and bled the caliper but only the one side will move again. I put an old pad on the moving side and not the frozen side is still stuck. I took it back out and it is now on my bench with the frozen side soaking in Kroil & P.B. Blaster combo running around the stuck piston. Is there anything else that I can do?
I feel that all of my wheels will be close to this as, I bought the car new and I have only driven it 15k. The Porsche gods are angry at me. I have the kits for all 4 wheels and 4 new rubber brake hoses. Can I get some help help please? I do not want to go the route of the grease gun as that will clog up the whole assy and I will have to separate it to clean and then find a gasket kit. The penetrating oil will bleed out.
Jack
1988 Porsche Carrera
Old 07-08-2010, 04:18 PM
That car is like a time capsule. It probably has a ton of issues to work through. You might donate that caliper to the natural history museum as a fossil. If a LITTLE BIT of heat doesn't get it, use it as a core for a new caliper.
Old 07-08-2010, 06:39 PM
I'm here to cause trouble
jimbauman's Avatar
Let me guess... the piston that didn't come out was on the outside? Reinsert the other piston, hold it in place with a clamp, and use air pressure to blow the stuck piston out...
JB
'86 Carrera Cabriolet '73 911T Sporto (RIP)
'90 Miata LeMons Contender! '71 Datsun 510 (RIP)
'67 Fiat 124 Sedan (RIP) '72 Ford Pinto (RIP)
'62 Plymouth Valiant '60 Ford Galaxy 500 (RIP)
Old 07-08-2010, 07:10 PM
it might be safer to just use the master cylinder and your foot, while using a small c-clamp on the unfrozen side.
Old 07-08-2010, 07:21 PM
jimbauman's Avatar
Good point - the piston can shoot out like a bullet....
Old 07-08-2010, 08:41 PM
pete3799's Avatar
Push the stuck piston in and try it again.
Mine were stuck but would push in and after several tries was able to get them to pop out with compressed air.
Pete
79 911SC RoW
Old 07-09-2010, 05:46 AM
burgermeister's Avatar
I had to use 100psi to pop mine out. Wear safety glasses, and have a thick piece of wood inside the caliper to catch the piston. If your fingers are in the way, you will not get them back, so be very, very careful.
The on-the-car method is certainly safer, and the 1000+ psi your brake system can provide should get any piston out ....
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 07-09-2010, 06:30 AM
I had the same problem on the rear, outside and just replaced it with a rebuilt on from Autozone of all places. Has been work well for a couple of years. Good luck. Steve
1970 911T SOLD
1989 3.2 Carrera
2013 991 Carrera S
Old 07-09-2010, 06:54 AM
