My other ride is a C-130J
'83 SC motor oil leak dramatically decreased!
The title pretty much says it all. My '83 SC motor was pretty good at leaking oil. At 135K miles I had the carrera chain tensioners installed and while the engine was out the obvious leak areas were addressed. The case WAS NOT cracked.
Immediately after getting the car back I noticed that after driving it there would be oil leaking from the case. It would stain clean cardboard three different areas about two-three inches in diameter. I assumed this was going to be par for the course. However, after driving the car for 500-600 miles the sizes of the leaks decreased, maybe two circles the size of a quarter each! ![]() The oil level, and oil pressure all have stayed constant. I was told once that after changing seals/washers the car will often leak less after being driven a few hundred miles. Is this true? Any ideas why the sudden improvement?
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
83 911 Production Cab #10
Did you change oil brand? Which one are using?
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Not sure of the brand of oil used. TRE did the previous Oil change, so you know the correct brand/weight was used.
My friend who did the chain tensioners rebuilds and races 911s all day long, so I assume he also used the proper brand/weight. It is possible he used a heavier weight. . . worth looking into.
BP could use a man like you.
1979 911 SC Silver 2002 996 race car 2005 Ford Excursion |
In the Land Rover world when it stops leaking it's out of fluids.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
I switch to dyno oil (Brad Penn Green Racing Oil) and the leakage drop by 50%. If the engine has the original seal you should not use synthetic oil.
ABSOLUTELY! Only the Cayenne and Boxster get the Mobil 1 Synthetic.
