-   -   964 spoiler conversion - switch p/n (http://forums.pelicanparts.com/porsche-911-technical-forum/552384-964-spoiler-conversion-switch-p-n.html)
Ray 911s 07-09-2010 08:00 PM
I have the switch for manual control of the 964 spoiler, and an AutoLoc controller. I think I need the factory switch mount or cut-out so I can mount in my shifter console. Does anyone have info on mounting this switch in a panel?
BTW - the switch I found is 993 613 203 0001C. Socket or mount part numbers?
Thanks!
rattlsnak 07-10-2010 12:52 PM
http://www.porsche.com/all/media/pdf/originalparts/en/E_964_KATALOG.pdf
go to page 528...
James Brown 07-10-2010 07:20 PM
Yeah that part is over $200 The switch is $60! you can use a window switch mounted on the door for $12. Problem with the factory switch is it only fits in the factory mount that only fits a 964 center console. Or use a on-off-on switch mounted on the dash for a few bucks. Been there, doing that..
rattlsnak 07-10-2010 08:06 PM
@ $ 50 for both from a salvage yard.. but yes, a window switch will work.
