beancounter
quick piston replacement job ---> oil pooled in cylinder?
Here's the skinny...pelican Vin-Barrett's '83 SC started blowing major smoke last week. Lots of oil in the tailpipe. Spark plugs were pulled and found that #6 was very oily. Diagnosis: lunched ring(s), possibly lunched piston and cylinder on #6.
The plan: quick engine drop, pull the heads on the right bank, replace #6 piston and cylinder with used parts from the spares collection, plug engine back in and continue driving like its stolen. engine out: ![]() vintage Oldsmobile workbench: ![]() heads off, #6 jug removed: ![]() what have we here? ![]() #6 piston. Stone cold busted: ![]() Unsurprisingly, there was oil pooled in #6 cylinder. What is puzzling is that we also found oil pooled in #4. #5 was clean. Note that the #4 sparkplug was clean, and it did not appear that oil was being burned there. Question is, how did the oil get in there? Why is #5 dry but #4 is not. The oil in #4 led us to believe that it might also have a ring or piston problem so we pulled the jug. The rings and piston were fine, so the question remains as to origins of the oil in #4. Anyone have any ideas or similar experience?
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Without seeing everything for myself, I can only offer an educated guess, but with that piston destroyed by detonation, lots of oil gets pumped into the airbox and the resulting crankcase pressure will push oil into most of the other cylinders.
I would certainly address the root cause of the detonation otherwise you are likely to have an "encore performance".
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
beancounter
Thanks for your input Steve. It was also my guess that the crankcase pressure pushing oil through the intake was the reason for the wet #4 jug. The only reason we had trouble with this theory is that #5 looks perfectly dry and normal. I suppose one could assume that when the engine was stopped and allowed to sit, that the #4 intake valve was open and #5 intake was closed, but wouldn't you expect to find oil pooled in the #5 intake port?
Please tell me you are NOT going to work over the engine with a cigarette in your mouth!
The ash from that thing is metallic and will get into the bearings and undo all your hard work. If you ever get a chance to go to a professional engine builder and watch a race engine being assembled by technicians wearing all white clothing and masks over their mouths, you will get the idea that dirt is the enemy. Good luck on the repair. Bob
Bob Hutson |
wannabee wannabee
Good luck and hope all goes well. Thanks for introducing me to my first fun run. My son and I enjoyed it! Hope to see Vinny next time.
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) |
Wil84911, when were you guys in Bloomsbury?
______________________________ Dave 1969 911T Coupe 1972 911E Targa Last edited by dafischer; 07-11-2010 at 02:05 PM.. |
wannabee wannabee
Dave, this past monday 7/5 around 8AM. I was tagging along so not sure of the route.
Registered Lunatic
I'm assuming you haven't pulled those other pistons yet (and would be hard pressed to do it if avoidable) and would also assume that if those pistons had some kind of unseen damage you'd see scoring on the walls. I would check tolerances (the best I could) on the bad piston. Looks like all of the rings were somewhat destroyed so checking ring gap is probably out. Check the piston good though and if it appears (other than the obvious damage) to be well worn then you can place bets that you have other cylinders with the same wear. i.e. . . could the pooling just be P/C wear?? I'm sure you're looking for the reason too. And if it happens again, take his keys.
If'n I tell ya a rabbit can pull a freight train, then son, hitch his ass up! |
beancounter
![]() Quote:
I used to live down the road from there on Rt 627...we went across the Riegelsville Bridge and then down to New Hope on Rt32/River Road. Quote:
Take his keys? Whatever for? Drive 'em hard, break 'em or wear 'em out, fix 'em up, then repeat. I met Vinny because he responded to my plea for assistance on my first engine drop. He helped me at several stages of my DIY engine rebuild and then helped me plug it back in to the car. He's a true Pelican.
I live off Rt 614 on the east side of the mountain, and there really are some great roads out here in Bucks, Hunterdon, and Warren counties. River Rd. to No Hope is a nice run, if you don't get stuck behind some rubbernecking Touristas. Let me know if you're going to be out this way sometime, and maybe I could join up with your group, if you don't mind a longhood tagging along. I might be able to get another friend in his 930 along as well.
______________________________ Dave 1969 911T Coupe 1972 911E Targa |
beancounter
PM'ing you my contact info. Good chance we'll be back...I will for sure as my father still lives out there. The more the merrier and longhoods are cool.
That first picture is one of the best I've seen here in a long time! The composition tells the story. good job.
Scot 78 911SC coupe ..."my friends all drive Porsches, I must make amends.." |
Was there regular gas in the tank and not premium ?
So did you guys finish up and get her back on the road on Sunday?
I'm sorry I didn't make it over to lend a hand. I finally got to ride the wheels off my bike this weekend after last weekend's fun with head gaskets! |
I took off my work clothes for the picture, and a smoke... This is me in my work gear when working on cars.... ![]() Thanks for the advice -vin
-Vinny 1983 911SC |
Sorry we missed you.. The motor is all back together, probably stick it in Friday after work
-Vinny 1983 911SC |
Cool!
So, what was the cause of the detonation? Sorry, I won't be around on Friday evening, either. I'm going to Myrtle Beach. Good luck, man. Last edited by Ed_; 07-13-2010 at 09:54 AM.. |
Thread Tools | |
Rate This Thread | |
