What can I add that hasn't already been said... Oh yeah, instead of (or in parallel with) the swapping out the thermostat you can install a switch to trigger the fan. That way you can just turn it on and forget about it while at the track. It may be easier to get in their with the wiring rather than swapping out the thermostat.
The only other things to remember are expect to need to flush the brakes more often, and the oil as well if your engine temps get real high during the day. Also, shiny side up, keep it on the pavement, and most importantly, have fun ![]()
Don't Lift... Don't Lift... Don't Lift ![]() ![]() ![]() '75 Targa in "Arrest Me" Red, 3.0SC ('79) engine, Bilsteins, Turbo Tie-rods, SSIs into 2-1 M&K muffler... and looking for my next upgrade. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fires are no fun-On or off the track!
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 07-13-2010 at 01:24 PM.. |
porsher
My 86 has 210k miles and I run it full on at DE with no ill effect.
X2 on brake and oil checks. Check oil temp when you have a few seconds to relax(!) on a long straight, every lap. If temp creeps above 250 you may want to back off because the oil begins to break down. If you do slow down, pay close attention to others. You will have a blast!
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
just me
I have a trombone cooler and a 3.2. the temps never went above 210, but it was cool each day. I would definitely want as much cooling as possible if I ran in the heat of the summer.
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
You have an active imagination
Where did you get you car lowered?
Im in staten island |
There are lots of excellent shops down there, one would be Deman but there are several other good choices
Used User
Which is not human nature. ![]()
My FB page: www.facebook.com/oddjobfix Antique and Collectibles Repair and Restoration On YouTube at "oddjobfix" |
Go Speedracer, go!
Thanks.
1981 SC ROW Coupe |
911s used on track are heat stressed, you want the highest boiling point you can get, I weight wet performnce somewhat more than dry here are some #s DRY:401F -- WET:284F --- DOT3 MINIMUM (GLYCOL BASE) DRY:446F -- WET:311F --- DOT4 MINIMUM (GLYCOL BASE) DRY:500F -- WET:356F --- DOT5 MINIMUM (SILICONE BASE) DRY:500F -- WET:356F --- DOT5.1 MINIMUM (GLYCOL BASE) DRY:527F -- WET:302F --- AP RACING 551 ($12.95/0.5L OR 16.9 OZ) DRY:527F -- WET:347F --- VALVOLINE SYNPOWER DOT3 & DOT4 DRY:536F -- WET:392F --- ATE SUPERBLUE/TYP200 ($9.95/1L) DRY:543F -- WET:349F --- Endless The truth DOT 4 ($35/1L) DRY:550F -- WET:284F --- PERFORMANCE Friction Z rated ($6.27/16 OZ) DRY:550F -- WET:284F --- FORD HEAVY DUTY DOT 3 ($4/12 OZ) DRY:570F -- WET:284F --- WILWOOD 570 ($5.65/12 OZ) DRY:572F -- WET:284F --- US Brake/AFCO Racing 570 Gold DRY:572F -- WET:421F --- US Brake/AFCO Racing Ultra HTX DRY:577F -- WET:300F --- Brake Man DRY:585F -- WET:421F --- Earl's Hypertemp 421 DRY:590F -- WET:410F --- AP RACING Super 600 ($16.95/0.5L OR 16.9 OZ) DRY:593F -- WET:420F --- MOTUL RBF600 ($12.95/0.5L OR 16.9 OZ) DRY:590F -- WET:518F --- CASTROL SRF ($69.00/1L 0R 33.8 OZ) DRY:601F -- WET:399F --- BREMBO LCF 600 PLUS ($26.75/0.5L OR 16.9 OZ) DRY:610F -- WET:421F --- NEO SYNTHETICS SUPER DOT 610($11.95/12 OZ) DRY:610F -- WET:421F --- PROSPEED GS610 ($39.95/16 OZ) DRY:617F -- WET:413F --- Endless RF-450 ($45/1L) DRY:620F -- WET:425F --- COBALT SUPER XRF [seem to no longer be available] DRY:622F -- WET:424F --- Endless RF-650 DRY:626F -- WET:417F --- WILWOOD EXP 600 ($16.95/0.5L 16.9 OZ) you'll notice that SRF has the highest wet bp out there, it's also the most expensive
Most street cars that go to DEs come through just fine. Some do not. If you get off track, anything can happen. I've seen quite a number of cars seriously damaged, and a few destroyed completely at DEs.
Bleed your brakes, watch your oil temp, and follow instructions. You should be OK.
1979 911 SC Silver 2002 996 race car 2005 Ford Excursion |
Hope that clears up my opinion of ATE Blue. You will be fine, but I would switch to ATE Gold (or one of the other even higher temp fluids) at your next service.
Gary R. |
I've used ATE superblue for years, both racing and DEs. Never had a brake issue that was related to the fluid.
+1 on ATE Superblue and I also switch between the ATE Gold routinely during changing of fluids.
SAM DACOSTA 1990 Porsche 911 Cabriolet (964) 2000 Porsche Boxster (986) 2002 Porsche 911 C4S (996) |
Dry:550f -- wet:284f --- ford heavy duty dot 3 ($4/12 oz)
Gary R. |
Having driven a couple of hundred track days over the last 6 years let me offer the following observations.
In agreement with milt the suggestion that a DE will damage your paint less than driving on the street is simply not true. You will be running in much closer quarters, at higher speeds and will be pelted in invisible sand. The front of my GT3 which has less than 20k (all track) miles looks awful from sand blasting and I have replaced the windscreen twice as result of track damage. Apart from this, DEing does not need to do any more damage to your beautiful car. But that will be entirely up to you. Porsches are meant to be driven quickly but they are not meant to be abused. If you arrive at the track and think you are Michael Shoemaker and drive it hard and "fast" you will almost inevitably do it an injury. Your car will reward you with both speed and longevity if you take the time to learn a smooth and consistent technique. Don't worry what any one else is doing do what feels smoothest and least abusive. Brake pads and fluids are critical. Pads should be at least half width when you finish - not when you start. Always carry a full set of spare pads and the tools and knowledge to change them. Have your brakes flushed and refilled with high temperature break fluid at least annually. Have them bled before every event. ATE blue or gold are fine. That is all I have ever used. In the early days of DEing I would not worry too much about running temperature. If it is not overheating on the street it will be fine on the track for as long as you are in the Instructed groups - probably further. Either Jacobs or Deman are very trustworthy people and are both extremely well qualified to help you getting set to go. Hope this helpful. Laurence Last edited by jittsl; 07-14-2010 at 01:44 PM.. |
Thread Tools | |
Rate This Thread | |
