AC calculations - ratios
Is there a ratio or sizing that the evaporator and condenser are supposed to follow? Like should the proportions of one be in a certain relation to the other? Thanks!
In a perfect world yes but not with a 911 or 930 and certainly not if you have different heat exchanger materials or designs; you might as well call it an art which it is.
Think of BTU's. You are removing xxxx btu's from the cockpit and dispersing them outside the cockpit. |
Thread Tools | |
Rate This Thread | |
