Kendall's Avatar
Send a message via Skype™ to Kendall
1987 Carrera G50 Lube change
Hello! I recently purchased a 1987 Carrera 3.2 with G50 transmission. 57000 miles, Guards red and beautiful. I want to change the lube in the transmission but am unfamiliar with the process.
If anyone has the process or a web link, tech specs on type and amount of lubricant, suggestions as to the brand, and torque specs, I would really appreciate learning these things. I've been running Swepco in my 1986 951 with great results. Much quieter and shifts well.
Also looking to see if there are other Pelicans in the upstate SC area.
Thanks!
Kendall
"Chance favors the prepared mind."
Old 07-11-2010, 05:42 PM
Diss Member
Quicksilver's Avatar
The technical spec book lists the G50 as taking 3 liters of 90 weight GL5 gear lube. There is a drain plug on the bottom and a fill plug on the side. From personal experience I can say that it definitely took less then a gallon to fill it. Torque for the plugs is listed as 30 Nm (22 ft-lbs).
Swepco made an improvement in the shifting on my car and is generally recommended.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 07-11-2010, 05:52 PM
Kendall's Avatar
Thanks! Great information. I'll give it a shot this week.
Kendall
Old 07-11-2010, 07:10 PM
timeless beauty
rcaradimos's Avatar
Make sure you loosen the fill plug before you drain, this is to ensure you are able to fill after draining. Good advice that some have posted here. I did mine and it helps the cold gear box shifting.
All the best
Bob
87 targa
Old 07-11-2010, 07:23 PM
muck-raker
kidrock's Avatar
some people will recommend Mobil Delvac over Swepco in their G50's. I recommend purchasing the hand pump from our host, it will make the job go a lot easier.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 07-11-2010, 07:28 PM
3.4 Bigger is better
88-diamondblue's Avatar
Welcome to PP. Synthetic is recommended for the G50 transmission. I have used the off the shelf Mobil 1 but the best that I have used is the Mobil Delvac Synthetic Gear Oil. It is Porsche factory fill. Here is a link to where to buy. Ln Engineering Owner of LN Engineering is a member here at Pelican and contributes a great deal of knowledge as well
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 07-11-2010, 09:05 PM
GrantG's Avatar
I concur - good info above
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 07-11-2010, 09:07 PM
I found it here.
Synthetic Gear Oil, 75W 90 - Oils - Lubricants - Power Tools & Metalworking : Grainger Industrial Supply
I used this method for filling.
G50 Synthetic Tranny Oil Change Completed (pics)
1987 Carrera
Old 07-11-2010, 10:30 PM
