-   -   Knock sensor wiring? (http://forums.pelicanparts.com/porsche-911-technical-forum/552728-knock-sensor-wiring.html)
brentrussell 07-12-2010 01:12 AM
Not 100% sure what this is....located left hand side rear of engine.
Can someone tell me which wire goes where?
1x Yellow
1x Red.
Thanks for your help.
http://forums.pelicanparts.com/uploa...1278922283.jpg
Won 07-12-2010 01:17 AM
I'm fairly certain that they're are thermotime switch for cold start valve operation with CIS injection. Definitely not a knock sensor. Aren't the spade connectors 2 different sizes and the sensor also has 2 different "buttons" so they can only go on one way? That's what I remember from mine anyway.
ischmitz 07-12-2010 03:51 AM
Yes, this a thermo switch and the connectors can go on either way - it doesn't matter.
brentrussell 07-12-2010 07:24 PM
Had another look at it today and you are right, two different size spade terminals. Another mission completed.
