AC repair help
So it is getting pretty hot around here, and the ac on my 1995 911 is weak at best. I have recharged it twice, up to about 35 psi. Even immediately after recharging it does not cool very well. After a few days (a week?) the pressure drops to 25 psi, or less. Any advice on how to proceed to find a leak, which hopefully may be somewhere that I could actually repair without extraordinary effort? I have a vacuum pump and AC guage manifold.
thanks.
Dave, in western MA.
1995 993
Old 07-12-2010, 06:27 AM
you may need to put a dye in the system and then use a black light to locate it. One thing you should replace is the drier tank.
Tony G.
2006 Cayman S
1973 914 1.7 project
"Rules are for the interpretation of wise men and the obedience of fools." Colin Chapman, Founder, Lotus F1
Old 07-12-2010, 07:02 AM
T77911S's Avatar
you can look for the wet spot. usually dirt will collect where the leak is if it is bad enough. another thing to do is use a sniffer. if the evap or expansion valve is leaking, sniffing the vents will let you know. found a bad evap in my brothers 930, goona check his volvo today.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 07-12-2010, 08:58 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
