Alignment changes as car is lowered
When lowering a car using the adjustment screw on the control arms.
Does it generate toe-in and negative camber or Toe-out and negative camber?
'65 912, '06 Cayman S 77 C3, 85 Carrera, 75 911S, 88 Carrera, 96 Carrera - Gone |
Max Sluiter
Depends on where you are currently. Can you post a photo showing the angle of your A-arms and tie-rods?
911S 1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance http://www.flickr.com/photos/max_911_fahrer/ |
A arms are above horizontal.
They were at horizontal, and then I adjusted the screws to lower the car. This brought the arms above horizontal and increased camber. I'm trying to find out what this does to my toe.
'65 912, '06 Cayman S 77 C3, 85 Carrera, 75 911S, 88 Carrera, 96 Carrera - Gone Last edited by awdbandito; 07-12-2010 at 02:16 PM.. |
Under the radar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
You can get a general idea of your toe using a tape measure. Or you could set up some strings and get a more accurate measurement.
Platinum Member
Did you lower rear also? If you increased the angle away from horizontal, that effectively shortened the toe arms. Last edited by dad911; 07-12-2010 at 03:39 PM.. |
I had a reputable shop lower my 911SC (1979) front and back. Afterwards it handled terribly. Then I went and had a full alignment by a shop that the 1st shop recommended, and it felt loads better!
Grand Am/IMSA Data Guy
Look at the tie rods. If they are to the rear of the spindle and they also angle up like the A arms, then you are adding toe out. If the tie rod is in front of the spindle, and the same change is made, you are adding toe in.
Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ |
Used User
![]() When a 911 is lowered past the tie rods being level, you are adding to toe out. This is why a steering rack spacer is used to reduce bump steer at the lower height.
My FB page: www.facebook.com/oddjobfix Antique and Collectibles Repair and Restoration On YouTube at "oddjobfix" |
I belive lowering increases neg camber and toe in untill the A arms are 90 deg to the strut which would have to be really, really, really low.
neg camber but I think toe out, because the tie rods are pulling in the rear of the wheels.
Fat butt 911, 1987 |
Max Sluiter
Usually, you get more camber and more toe-out.
I got my 930 25 years ago next week. It was in perfect shape inside and out. On my backroad course it would go over 150 easily but was squirelly no matter alignment or tire. I had a turbo s spoiler and a Ruf front installed, went to 17 inch turbo twists, lowered front, and the one they said helped the most, corner balanced. The reputable shop said that it was pretty effed up. The car had only had one owner and the front right fender replaced in the prior 9 years. Cutting back to the chase it was as planted at 150 as it was at 90.
PRO Motorsports
You will get more negative camber and it will toe-out.
'69 911E coupe' 2.7E MFI (retired 911-Spec racer) '72 911T Targa (Formerly "Scruffy") 2004 GT3 |
thanks for the info. I am pretty sure as I lowered the car I ended up with toe out and additional negative camber. I was just trying to make sure.
Got it, as the car gets lower the bottoms of the struts push wider because of the A arm effect adds neg camber.
However, I believe the tie rods push out until they get to square to the ground . After that they then get shorter as they start to angle upward toward the struts. So I suspect lowering most always increases neg camber. However when lowering from stock height, at first it toes in, then at some point past "euro heigh look" can start to toe out. |
PRO Motorsports
This was designed in from the factory. Not only are the control arm and tie-rod not parallel, they are also different lengths. Plus the tie-rod is moving in a uniform arc, while the steering arm is not. Makes things a little more complicated than meets the eye.
Max Sluiter
This is in interesting puzzle.
Spit balling, it seems the A arm and tie rods move over two different arches. This is why a lowered 911 is subject to bump steer. I believe struts mostly widen with compression or lowering unless one goes extremely low. If any thing the rate slows quickly. Think of a flattening camber curve. The tie rods however move over an arch where there attachment points gets wider at first and part way through compression they narrow increasingly. I believe that going from stock height the rate the struts move apart is slower than the rate the steering arms move apart. Then the rate the steering arms move apart slows as the struts continue to move apart. Finally the rate the struts spreed apart starts to slow but the rate the steering arms are pulled together starts to steepen. Thus, I suspect with lowering at first there is a slow increase in toe in, then a range where toe change is more or less stable. Then as the car gets low, we start getting in increase in toe out. This is where we start being very aware of bump steer. |
Max Sluiter
Someone needs to take out the torsion bar and make a video of the suspension moving throughout its travel. Any volunteers?
PRO Motorsports
I've measured bump steer on a lot of cars and can tell you that you'd have to raise the car pretty high to have the bump-steer curve you are talking about.
Thread Tools | |
Rate This Thread | |
