J Chisholm
oil pressure
Have an 88 Carrera..and have a question about the oil pressure . I have only been driving it for a couple of months, and have noticed a change in the gauge readings. Used to be around the 5 mark cruising on the hwy, and between 2 and 3 at idle. Suddenly it's around the 4 mark hwy, and bouncing around 1 at idle. Lots of oil in it, and may not be an issue...just curious what is "normal"...
Hotter temps can cause lower oil pressure as well as the oil breaking down. What grade and brand of oil are you using?
By "lots of oil", what do you mean? Did you check the oil level correctly? Rule of thumb is 10 PSI per 1000 RPMs so your does seem to be "normal".
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
J Chisholm
Am using Brad Penn 20/50 oil level is between the marks on the dipstick, at idle, hot engine. I don't think there is anything wrong, doesn't seem to be anyways. Was just curious why the sudden change. Could be just one of those things...thanks for your response
Max Sluiter
could be the sender going bad.
911S 1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance http://www.flickr.com/photos/max_911_fahrer/ |
Sounds as if you are using the right oil and checking it correctly so I would just watch it for now.
![]() BTW-Is Legendary Motorcars based in Bowmanville? Your city sounds familiar.
Virginia Rocks!
OP, what does "bouncing around 1" mean?
Mine is usually a little north of 1 bar at idle and 10 bar per 1000 rpm as mentioned. If it flickers like mad it might be the sender.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
83 911 Production Cab #10
... Curiosity killed the cat but satisfaction brought him back (up to 8 times)
![]() ![]() ![]() I`m no expert (even though I tell my wife that I`m a genius... but can not print her reply ![]() ![]() ![]() The rule of thumb is, 1 bar (10 PSI) mark on the Druk gage (gauge, dial, Lehre, thingny, whats you call it) per 1000 Rpm. So 1 at idling and 5 at cruising on the highway is fine. +1 on the Brad Penn 20/50. You are correct... Nothing wrong ![]() ![]() ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 07-12-2010 at 07:49 PM.. |
![]() Quote:
![]() ![]() ![]() Not to be picky but you either meant; 1 bar per 1000 rpm or 10 psi per 1000 rpm. Definitely not 10 bar per 1000 rpm.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
1 bar does NOT equal 10 psi.
1 Bar = 14.504 PSI. Quote:
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Brad
In my "rush" to answer I did not check my book (1 bar = 14.5037738 pounds per square inch) so I'll publicly eat a piece of crow pie as long as you supply the wine ![]() ![]() ![]() ![]() ![]() ![]() The main point was that 10 bar per 1000 rpm was incorrect, but 2 wrong does not make one right. J.J.
Max Sluiter
Jeez. it was just a typo.
Do not worry unless you are less than 10 psi per 1000 rpm. 1 Bar is considered the target.
911S 1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance http://www.flickr.com/photos/max_911_fahrer/ Last edited by Flieger; 07-13-2010 at 12:15 AM.. |
![]() Quote:
![]() ![]() ![]() It's funny there is a lot a misconception when it come to the Druk & Oil Level Gage (I'll spare you all the other name for it). My PO though if both of them were at the top at any given time it was good... Not knowing any better, I believed that until after cleaning the connection for both sensor which resulted in normal operation which prom me to ask the usual question. Druk vary with the RPM and the Oil one is only good when idling on a flat surface.
Max Sluiter
+1
Actually, I could not post the pics since I was in to deep ![]() ![]() ![]() After, the BBQ Whale tail, Canadian beer Fridge (bias), this is my favorite one ![]() ![]() ![]()
J Chisholm
Legendary I believe are in London, Ontario. I could be off a bit, but I know they are nowhere close to me. What is very close is Mosport..legendary ancient F1 track...still in use by all kinds of speed deamons...again, thanks for all the replies...
Love the pic!
No harm. No foul. I have made far worse mistakes. Just wanted to correct so the OP wouldnt think his system was off based on PSI numbers...
I love wine.... Although your beer cooler looks more interesting...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 07-13-2010 at 07:11 PM.. |
![]() Quote:
Just return from Niagara On The Lake and brough back 10 cases ![]() ![]() ![]() ![]() ![]() ![]() Thes are my two favorite photos. I posts them as much a much as possible. A ta Santé... ![]()
Thread Tools | |
Rate This Thread | |
