grahamkissack's Avatar
Bench bleeding a MC was a waste of time
Just installed a new mc tonight for my SC as part of my effort to achieve braking nirvana. To do everything right, I also bench bled the mc before hand. I just filled the reservoir to the point there was fluid in the reservoir bottom and down the hoses to the mc. It took about 5 pumps on the end of the actuator on the aluminum housing before the pair of tubes back to the reservoir ran bubble free.
I took off the tubes and proceeded to install the assembly. I guess thats why they call it gravity bleeding!...I lost most of what I put into the mc through the open ports as I connected the brake lines. By the end of the process, the first few pumps of the mc were air again. Perhaps I'm an idiot, but I just don't see anypoint in wasting time and creating a mess with this step. Usually when I install brake components, I don't spill a drop. This time I put my paint in jeopardy and left a disaster in my trunk.
"Penelope" 1980 SC Targa in Grand Prix White
Old 07-12-2010, 10:20 PM
Senior Advisor
James Brown's Avatar
Your right, It's not like a 64' Chevy!! Fluid flows down hill pretty well.
08 Cayenne Turbo
Old 07-13-2010, 11:12 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
I had the same experience the first time I replaced a MC. The second time I didn't bother bench bleeding and had no problems. It was a much cleaner repair with out the bench bleeding step. With a pressure bleeder and a round of traditional bleeding, all air was forced out of the MC.
1981 SC ROW Coupe
Old 07-13-2010, 02:33 PM
Senior Member
Jdub's Avatar
I had the same experience - but bench bled the MC only to remove any particulates, etc. that might have somehow found their way in (even though they cap the openings).
Only want to add that getting OEM brake switch w/ the MC ensured that I wasn't replacing these items since I had gone cheap with the VW equiv. in years past. I really don't like replacing the switches and having to bleed those ports! Folks might weigh the cost of replacing the MC outright if they "lose" their braking lights via bad old switches and they know the MC is hitting its shelf life.
'78 Targa | WANTED TO BUY - NORTON COMMANDO PARTS - PLS MESSAGE.
Old 07-14-2010, 07:05 AM
i never pre-bleed them. waste of time.
206 637 4071
Old 07-14-2010, 08:57 AM
sww914's Avatar
Agreed, waste of time and a big mess.
I hook up the reservoir lines and leave the hard lines a little loose. I fill the reservoir and let it sit until the fluid drips out at the hard line fittings and then tighten them. It gets the air out faster than trying to pump it out. I also loosen the fittings at the calipers and let it sit until they drip and then tighten each one. Then I loosen the bleeders at each caliper and let them drip, tighten them, and bleed normally. It keeps it from being a frustrating job, unable to pump the air out for too long.
Additionally, it cuts back on the whining sound escaping from you helper's lips, "my leg hurts!".
I had a pressure bleeder and I've had a vacuum bleeder but I like to do it like this because it's more effective IMO.
Old 07-14-2010, 09:08 AM
Next time, perform this procedure with a PVC tube attached to the bleeder screw. Curved upward, you can observe the air bubbles exiting. No bubbles = no air in the system. You can also pump the pedal to help evacuate air on both ends of the system w/o drawing in any air. Minimum waste of BF too, especially the pricey stuff.
Sherwood
Old 07-14-2010, 12:51 PM
Burn the fire.
Brando's Avatar
Get a power-bleeder (or pressure bleeder) and save yourself the time of "bench bleeding" the MC.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 07-14-2010, 01:03 PM
Northern Motorhead
wildcat077's Avatar
Guys,
I replaced my complete brake system over the Winter... Big Red calipers,new 23mm master cylinder,stainless flex lines and had to hand fabricate all four solid lines !
I just added a minimal amount of fluid to the new master before installing it and used gravity to bleed the whole system,including the clutch slave cylinder since i was now going to use ATE blue to be sure all the old fluid was out !
After i got some pressure in the system,my son and i bled the old fluid out the old fashion way,push down,hold ,bleed ,release and keep going ...
Although shortly afterwards i purchased a motive bleeder from Pelican with my last order !
Wish i had the Motive earlier,wouldn't have had to bribe my son with pizza for the help ... lol
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 07-14-2010, 02:53 PM
Jack
Though I haven't done a break job on my P-car, having done it on a Land Cruiser and Early Bronco, I would say that this is the best power bleeder I have used. I borrowed it from a mechanic friend, it worked great.
VACULA Automotive Products
Don't know how much they cost, or where to get one....
-Jack
85 Carrera Cab
15'3" Scout Sportfish
10'7" Michel Junod
Old 07-14-2010, 05:12 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
