mingmong's Avatar
Petrol tanks got a hole!
Haven't used my car for a while (about 6months). Started it up the other day and everything worked fine. Put it back in the garage and came back a couple days later to find a large pool of petrol all over the floor. Appears the tank has rusted and now leaks. I've emptied it now and was wondering what are my chances of repairing it and how? The leak looks to be around the pipe feeding the pump. Or is it a case of getting a new (and no doubt very expensive) replacement? Any advice always appriciated
Cheers -Mark
Emptying the tank
The hole in question
View from inside via the fuel gauge opening
Old 07-13-2010, 07:54 AM
Throw it on the ground!
I had the same problem not too long ago. Had a patch welded at a radiator shop.
Gas tank repair.
Who carries Wurth SKS in Atlanta?
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 07-13-2010, 08:21 AM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
I had the same problem on my '67 Beetle. I soldered on a patch made of copper sheet. That was twenty years ago, and it's is still O.K.
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-13-2010, 01:34 PM
It could just be the hose leaking. Usually the tank rusts in the bottom, not where yours is leaking from.
-Andy
Old 07-13-2010, 02:28 PM
mingmong's Avatar
I'll take the tank out as soon as I get a chance. Hopefully be able to locate exactly where the leaks coming from as it's not clear at the moment. Might be the hose but looks to becoming from higher up, though the inside of the tank wall looks OK.
Old 07-13-2010, 08:54 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
