Leakdown and compression results on PPI- opinions?
Gent's I'm looking at a race car with a built up 3.0L SC engine (J&E pistons, 10.5:1 compression, Weber carbs, etc). 46 hours on the engine in the past two years running HSR events. I had a Porsche shop do the leak down and compression on the car.
cylinder: leak down # compression # 1 10% 180 psi 6 12% 178 psi 2 5% 185 psi 4 8% 175 psi 3 25% 165 psi 5 20% 170 psi The mechanic said the leak is coming from the exhaust valves only. The car hasn't been run for 5 months. He said that leak down in 3 and 5 concerned him but then he did the compression test and thought that it didn't look as bad. Could carbon buildup and moisture absorbed in then carbon be a culprit? Is it worth having the mechanic remove the valve covers and try to tap the engine to loosen the buildup after running the engine a bit with some cleaner and then trying another leak down? If I am just doing track days (15 hours a year), can I wait a year or two before doing a valve grind or a top end? Or is it too risky and I should just walk away? The rest of the car is perfect. Brakes, suspension, transmission, clutch all great. Looking forward to opinions... James 1985 Carrera |
Home of the Whopper
That would be my first guess. Run it hard and try again.
FS: '71 911E Targa rustbucket - $20k |
James,
Whenever I see higher-than expected leakage from exhaust valves, the first thing I do is "stake" them to dislodge any loose carbon and redo the test. This involves removing the valve covers and striking the end of the rocker arm over the valve using a piece of wood and a small hammer. I also use this opportunity to measure the sideplay in the valve spring assembly as a test for guide wear.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Thanks for the input. That's what I was looking for.
James |
Thread Tools | |
Rate This Thread | |
