charge ac or not
recently purchased a 82sc the ac needs charged is it worth the effort, as i have read the ac does not work well on these cars, i know it won't be ice cold, and really don't want to upgrade a whole new system as i have a targa anyway but would like it to function if possible
1982sc targa blk on blk va beach va |
Used User
There are some simple and not too expensive upgrades before you spend money on refrigerant.
I'll let someone more familiar post a link to one of the many threads here.
My FB page: www.facebook.com/oddjobfix Antique and Collectibles Repair and Restoration On YouTube at "oddjobfix" |
You can have it converted to and charged with r134 for less than $200.
Used User
Where?
you can still get R-12 on a limited basis, and the hoses too.
I think a better question is whether your system needs work before a recharge. |
Just my .02 cents worth...you've got a system almost 30 years old that probably didn't work real well when new. I would rather not say how much I've spent ($$$ and time) on my a/c system and with all of its current faults, it's likely as good as it will ever be. If your expectation is to have a "functioning" a/c system (i.e. it holds freon and will make a little cool air from time to time), you can patch up (i.e. pull a vacuum, fix any significant leaks and charge the system) what's there; if your definition of "functioning" is something closer to new Honda/Ford/Toyota, then you best get out your check book. It's a slippery slope.
Marc Morrison 1964 356C coupe '89 911 coupe 2008 Honda Accord 2008 Ford Ranger |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
You don't need a lot of upgrades . The R134 has smaller molecules which make the system prone to leakage. Also, runs on higher pressures. Our A/C works quite well with R-12, but, within system limitation(s), and evaporator freeze-up can be an issue. All is stock, plus the additions of the Procooler, and a high flow evaporator. 40F-45F on a 85F day on the freeway. With these settings. You may pm me. Good luck, Gerry ![]()
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
You could borrow a vacuum pump and gage set from AutoZone. Pull a vacuum and check it for leaks about 24 hours later. If it is not leaking, buy a lottery ticket because you are very lucky, then spend $20 at Big Lots for R-134A and recharge it. You may have to spend another $15 for compressor quick charge fittings to convert to R-134A. The older hoses will leak slowly over time so plan to add a can of refrigerant every few months or so.
A more likely scenario is that you will have leaks and it will be a PITA to fix them all. There are a lot of threads that talk about improving the A/C to better than original performance. It is just a matter of how much time and money you want to spend. |
Here is another opinion. My 80 SC had a small amount of positive pressure in the system. I took a gamble and had some DuraCool (propane / isobutane mix) put in. Works VERY well. Stock system. Yes, the compressor is sort of lumpy. But I am not sweating.
Check the vacuum as above and move forward. BTW, my car has the stock front condensor but the fan doesn't work. Good luck, Larry |
Used User
When converting to R134a, don't you need to change the dryer? I think you should anyway. That's why I want to know how to get mine going for 200 bucks.
If it works initially but isn't working a week later then that's the time to begin trouble-shooting. |
wwest, as I understand it (I am no expert) you should always pull a vacuum to get any air out of the system before adding refrigerant. You also want to check for large leaks with a vacuum before adding refrigerant so it doesn't leak right out into the atmosphere. Autozone and others will sell the vacuum pump and gage set then refund the full price when you return it. They call it a tool loan program.
milt, I would also change the receiver/dryer because they are very inexpensive (ackits.com) For that matter it is also a good idea to flush the system of the old oil (mineral oil) and start by adding a known quantity of oil (ester or Pag) before recharging. I live in Atlanta and think it is worth the problems of keeping the A/C working. If I lived in Canada I probably wouldn't bother with it. It's also a bit of a hobby for me to work on the car when I have the time. If you would rather just pay someone to do the work it probably wouldn't be worth the cost of fixing it. |
i know a very good porsche mechanic that did nothing to his r12 sytem in his 930 except fix the leak/s and charge with 134. this was more than 5 years ago and it is still working fine.
if a system needs a charge, there is a reason, it leaks. finding the leak is the hard part. you could put some dye in there and put in a can or 2 of 134. if you cant find the leak, chances are it is the evaporator. replace the expasion valve if you have to get in there for that. if it was me, i would putr12 back in there. you can get it on ebay. i have a few cans still from when i bought some on ebay. the only thing i have left with r12 is my truck, but that has a bad metal line and i cant seem to find another one. i was going to put the ac back in the 911 but since i have been driving the 325, (COLD AC) i dont think i will. you could also put dye in and charge it with nitrogen. milt, ithink that $200 recharge is just that. pull out the old, perhaps a flush and charge with 134.
86 930 42kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 05 BMW 330CI 130K:: [_ ![]() 08 VOLVO V70 190K:: [_ ![]() 90 B2200[__] RUNNING:[ ![]() ![]() |
thanks for the responses
Thread Tools | |
Rate This Thread | |
