John W
How much brake fluid to do a flush
Hi, I'm getting ready to do my first brake flush. Still need to get a pressure bleeder but was wondering how many liters of brake fluid should I buy. I'd rather be on the safe side.
Thanks guys,
----------------------------------- John 89 3.2 Targa 123k miles |
abit off center
1 liter should be plenty.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
John W
Thanks Craig.
Formerly known as Syzygy
buy two litres and if you don't use one of them, you have the extra for next year. If you need more, you got it right there.
Might as well do the clutch at the same time.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
I switch back and forth from blue and gold - that way I know its flushed.
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
I would always get more than you need... I some how have managed on several occasions to have some of it end up on the floor. Pilot error... One time I un-did the pinch line on the over flow before releasing the air pressure on the bleeder can, just dumb mistakes, but when you don't do this all the time you can make dumb mistakes.
However the 1 liter can should be enough. The blue/gold is a good way to go...
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Using a pressure bleeder invariably leads to more BF needed than required.
Sherwood |
Northern Motorhead
Agreed with one liter... i did a complete brake replacement over the Winter and used one liter of Ate blue !
Pick up two liters to be on the safe side if you use a Motive bleeder. Don't forget to bleed your clutch slave cylinder above the gearbox !!! Cheers ![]() Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
I just did it after I replaced all of my wheel calipers and rubber lines and I used 1 1/2 qts of Castrol with a Motive pressure bleeder.
Jack 1988 Carrera |
Platinum Member
Now would be a good time to change the rubber lines if it's never been done.
New lines on a boxster, and bleeding the clutch took a little more than 1 liter. |
