Yep, I've done that!
joeblow's Avatar
WEBASTO heater help and advise.
Guys, I am moving to colder weather soon and have put the Webasto heater back on my list of To-Dos again. I have headers and don't really care to go back to heat exchangers, flapper boxes and such. Plus I think that I will end up needing more heat than that anyway!
I have a 71' that is unmolested and I would like to have a mostly original Webasto set-up, the problem is that I cant seem to round up all the goodies.
The item that seems the most difficult to find is the ignition unit.
Where I am confused is between the early and late systems and how they work. I have the parts lists but not the wire diagrams, maintenance info and functionality info. Does anybody have this info to share with me?
Also is there a work around for the ignition if I cant find it, ie.. from another car or similar?
I have the red burner unit, the resister, and the original switch. I have located the mixer/pump unit. From my understanding I need the main pump, wire harness and the igniter box as well as the exhaust system which I have seen available as a reproduction.
Thanks for your help in advance!!
What I have is pictured below...
71' 911 Fully restored Tarmac Rally Long Hood RSR
03' Audi Allroad 2.7ltr Twin Turbo 350 HP Ski Machine!
00' Aprilia RSVR Mille SuperBike highly modified...Yep fun fast!
86' 944 SPEC Car 'In Process' 2013 Debut
Old 07-28-2010, 09:55 AM
Fleabit peanut monkey
Bob Kontak's Avatar
I have the information from the factory manuals. PM me to discuss. Too much to post in this thread. There is information on how to convert the glow plug to a transistorized ignition. No idea if parts are available.
Old 07-28-2010, 03:20 PM
