Hi
Targa Me's Avatar
Miles Per Clutch
Hey Folks !
I was just wondering; about how many miles do you get out of a clutch disc? I know a lot depends on driving habits and such.
I have almost 100k on my clutch now.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 07-19-2010, 08:31 AM
"O"man(are we in trouble)
widgeon13's Avatar
In 45 years of driving, I've only replaced one clutch. That was on a 72 BMW Bavaria at 150K. I bought it new when I was in Germany. I've had many std. shift cars w/ over 100K and never replaced a clutch on any of them including my current Pcar. My wife also drove many of those cars and has always been an excellent driver of stick shift cars. In uncongested driving, I usually use the engine to slow the car down before braking, don't know if that helps or hurts but it's always been my driving habit.
As you mention, much depends on how the driver treats the car, I suppose the kind of driving as well, city vs highway.
I have also known people who have gone through a clutch in 30K.
Old 07-19-2010, 09:02 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
We replaced the original clutch in our '86 at 103,289 miles.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 07-19-2010, 09:04 AM
Not only driving habits, but depends on where you drive. Hilly country is a lot more punishing than driving on flat land.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 07-19-2010, 09:35 AM
Originally Posted by Targa Me View Post
Hey Folks !
You need to tell us what your car (year, etc.) is, for instance, some of the original SC clutches (rubber centered) were fairly short lived.
There are WAAAAAY too many variables to give a good answer anyway.
Terrain, driving style (clutch slipper? drag racer?), engine, car...
Could be 30k miles, could be 130k miles.
Old 07-19-2010, 09:49 AM
carreraken's Avatar
I got 125k on the original clutch on my 85. The rivets on the clutch disc were just starting to get ground away.
edit: I didn't replace it because it was showing any signs of slipping - but because I was getting too nervous about taking long trips knowing that my clutch was nearing end of life... turns out it was perfect timing.
Ken
06 Cayman S - gone
85 911 Targa - gone back home to Germany
73.5 911T Targa - long gone...
Founder ncPOG: nevada county Porsche Owners Group - disbanded post covid after 15 yrs
Old 07-19-2010, 09:54 AM
Checked out
McLovin's Avatar
I've replaced a couple of clutches, but only because I had the engine and trans out for other reasons and it was a "while you are in there" thing.
I've never replaced a clutch because it was worn out.
The most miles I've ever done was 180K, and the clutch worked fine when I sold the car.
Old 07-19-2010, 10:07 AM
Hi
Targa Me's Avatar
I'm aware of all the variables...
As far as I'm concerned: the car is an '84 Carrera with a stock 3.2 and my driving habits are non racer, not a ride-the-clutch kind of guy, mostly highway driving... but like I said, I was just curious what you guys were getting.
Old 07-19-2010, 10:32 AM
At the track = great day
ChkbookMechanic's Avatar
I have an '84 Carrera that I use for track days and an occasional drive to and from work. The drivetrain has never been dropped from the car, so the clutch has 107k on it.
Lane
2011 Volkswagen Jetta SportWagen TDI
Looking for another sports car..
Old 07-19-2010, 12:45 PM
rnln's Avatar
don't remember which year but we have rubber disk clutch which sometimes fail prematurely. Mine is making noise at around 70k+ miles. The rubber disk start cracking and separating
Fat butt 911, 1987
Old 07-19-2010, 01:05 PM
Those were only on SC's. 78-83.
Old 07-19-2010, 01:48 PM
gtc gtc is offline
abides.
gtc's Avatar
Mine was replaced at 87k, 160k, and 210k. The last one was a 'while you're in there' replacement, and was about halfway worn out.
Graham
1984 Carrera Targa
Old 07-19-2010, 02:25 PM
Peter Zimmermann's Avatar
The two primary limiting factors for clutch life on a 915 or earlier P-car are; (1) a leaking main shaft seal that allows trans oil to contaminate the disc, or (2) abuse.
#1 can happen at any time between 30,000 miles and 125,000+ miles, with 75-80,000 miles being typical. Improved seal technology has given clutches extended life.
#2 can be anything from frequent valet parking, to competition use, to poor driving habits.
Other things that can influence clutch life are the throw out bearing release fork (which can break), the crankshaft seal behind the flywheel (which can leak), the throw out bearing (which can get noisy/seize), or a broken pressure plate (extremely rare on pull-type clutches).
Benefits of not trying to set a world record for mileage (the parts replaced with the clutch are not designed to last more than 100,000 miles) are;
1. Replacement of the above-mentioned seals,
2. Replacement of the pilot shaft bushing/bearing (when this part fails it can damage the tip of the transmission main shaft badly enough to require replacement),
3. Replacement/resurface the flywheel,
4. Replacement of the TO bearing fork and its seal (915),
5. Clean & grease the TO bearing fork's shaft,
6. Replace the clutch disc, pressure plate & TO bearing as a kit.
FYI: The spring hub clutch disc, that replaced the rubber hub disc used in early SCs, was fitted to new 1982/83 SCs from the factory.
Keep the Shiny Side UP!
Pete Z.
Old 07-19-2010, 03:58 PM
There you go... ask Peter...
He wrote the book. Literally.
Old 07-19-2010, 06:41 PM
KCinBR's Avatar
Cant really add much to what has already been posted, but thelife of the clutch is really in the drivers hands (or feet).
That said I had to replace the clutch in my 88 Carrera at about 120k miles because of TOB failure, decided to do it all while I was in there, but the clutch actually had lots of life still in it,
KC
88 Guards Red Targa (sadly sold )
2005 Boxster S
1st Porsche 73 914 (long gone)
Old 07-20-2010, 02:27 AM
KCinBR's Avatar
My car is an 88 and had the ribber center clutch, replaced with spring center
KC
2005 Boxster S
Old 07-20-2010, 02:28 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
When you're talking Porsche 911's, and particularly aircooled 911's, there is an exception to every rule.
I know that my 81 euro SC had an original clutch when I replaced it, and it was a spring centered clutch. I also know from reading this board that most US spec Carreras seem to have rubber centered clutches. So, I don't think you can make a blanket statement like that. I don't think there is any concrete way to tell which clutch you have without physically taking it out of the car.
To the original poster's question: My euro SC had about 80,000 miles on the original clutch when I replaced it. It had worn down to the rivets and gotten into the flywheel a little. I did not know I needed a clutch, but had dropped the engine to rebuild the transmission when I discovered it. Since replacing my clutch, I had the cable adjusted incorrectly for several thousand miles. Upon dropping the engine a second time to fix oil leaks, I discovered that the clutch had worn prematurely due to the incorrect cable adjustment. So, there's another way you can burn through a clutch disc quickly.
1981 SC ROW Coupe
Old 07-20-2010, 06:34 AM
