Engine Case Oil Breather Connections
My 75 911,s engine compartment was a rats nest of improvised connections when purchased. I am now reinstalling the engine and there are two hoses that APPEAR to be oil tank connections. One from the air box and one from crankcase, two hoses and one connection on oil tank filler neck. Is there a "T" fitting I am missing or what? Viewed exploded diagrams and no help. Anyone with an answer on this? Thanks In Advance!
Jim,
The connection on the right side of the airbox goes to the upper fitting on the oil tank filler neck. The crankcase vent (top of engine) attaches to the lower fitting on the oil tank. The smaller diameter oil hose that connects to the left side of the engine shroud goes to the oil vapor cannister that should be located just forward of the oil tank on the right side of the engine compartment. This is a long hose that runs along the firewall.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL Last edited by Walter_Middie; 07-20-2010 at 11:00 AM.. |
