jwakil's Avatar
Weltmiester vs JM strut brace
I'm trying to decide between the more expensive Weltmiester vs cheaper (by ~$100) JM strut brace for my 83 SC. Any opinions on the quality and ease of installation of one vs the other?
Old 07-20-2010, 07:50 AM
tobluforu's Avatar
Do a search on strut braces, lots of info.
Old 07-20-2010, 08:41 AM
aj88cab's Avatar
I have the JM bar and I am very happy with it. Well made, very easy to install. The mounting brackets are now curved to fit the shape of the strut tower top (previously the brackets were flat). All in all a great value IMHO.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 07-20-2010, 08:54 AM
ToddM's Avatar
Send a message via AIM to ToddM Send a message via Yahoo to ToddM
People are still installing Welmeister stuff? lol
-Todd
'82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs.
Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete
Old 07-20-2010, 09:41 AM
gtc gtc is offline
abides.
gtc's Avatar
I don't understand why people continue to buy the Weltmeister in spite of it's known issues. It's pretty ugly on top of that, too.
Graham
1984 Carrera Targa
ToddM's Avatar
There are SOO many better alternatives these days. I've been running the BK bars exclusively on all my street Pcars for years now.
-Todd
Old 07-20-2010, 09:50 AM
Other than to clearnace the area around the Strut tower the ONLY reason I still have one in my car is I can fit a Full Sized Spare under it! But for Strength I used one that was Crossed Braced to a Place mounted on the Trunk floor.
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si
Old 07-20-2010, 10:28 AM
A strut brace for a 911 isn't a complex issue. Not sure there's a whole lot of difference when it comes down to it. At any rate, the end result might be negligible to minor in a street vehicle no matter whose bar is used. The WM is fine with a modification to the top plates. That said, I replaced the relatively heavy steel tube and hardware with lighter aluminum pieces and modified one of the mounts to add a triangulated bar. BTW, no access issues to the smuggler's box.
Sherwood
Old 07-20-2010, 11:10 AM
Elombard's Avatar
Wow that is nice sherwood, cost effective and probably a fun project.
As mentioned above the Weltmeister is a problem unless modified it does not let the top of the strut move mack and forth as the suspension goes up and down, this must force the bushings in the insert to really get hammered.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 07-20-2010, 01:39 PM
Thanks Eric. However, cost-effectiveness is relative. It is pre-owned, and I probably spent less overall compared to higher-priced strut brothers. However, what do they say about one's time and labor?
One more:
I like a challenge - like installing a reinf. plate, flat washers and lock nuts to the underside of the 4 mount bolts on the chassis. The only access is at 6 o'clock.
S
Old 07-20-2010, 03:24 PM
