911SC Alternator overhaul or not question
Hello folks,
Could you help in deciding if I need to overhaul my alternator/generator? The voltage regulator failed and smoked the battery... and I have 16V on tick-over to the battery now. After taking it out to see what regulator I should get, I see what could be allot of wear on the pick-up points on the shaft (see photo). Is this normal or too excessive? Bearings are good otherwise. Also, the voltage regulator has only one wire from it... and I see the ones on Pelican etc are two wire... but I have no second spade connector to connect it to! (an overhaul is around 280 or so euros with exchange (France), a regulator is about 35 euros.... first browse around for prices) Thanks for your help!! brd. http://forums.pelicanparts.com/uploa...1279656700.jpg http://forums.pelicanparts.com/uploa...1279656713.jpg http://forums.pelicanparts.com/uploa...1279656722.jpg |
since you have went this far you might as well, if just for piece of mind. Take the old parts (ft and rr bushing/bearings to) to your local armature shop, get the parts and do it youself, its not hard. cost me around 80 us.
Thanks. But the bearings are fine. It's just the pick-ups on the rotor that appear worn (how are they replaced?) and the voltage regulator appears knackered.
Also, does the two wire regulator replace the one I have (in photo above)? I have only seen two wire ones when I look online and I don't know where the second wire goes on my alternator... no second spade connector. brd. |
| All times are GMT -8. The time now is 09:34 AM. |
